All Things Mk5 => Mk5 General Area => Topic started by: bowkes7 on January 17, 2016, 06:48:10 pm
Title: Need help with squealing noise
Post by: bowkes7 on January 17, 2016, 06:48:10 pm
Hi when I start my golf gti there is a small squealing noise for the first 5 mins, after the car is warm this goes and sounds normal, was wondering if this was the cam belt that needed to be changed but was unsure as the noise goes
Title: Re: Need help with squealing noise
Post by: bowkes7 on January 17, 2016, 06:49:07 pm
Any help would be appreciated
Post by: r5gtt on January 17, 2016, 06:57:56 pm
Could be that the Auxilary/fan belt that's worn out or the clutch pulley on the alternator.
How long has the noise been there?.
Do you have a video to confirm the noise?.
Post by: AJG09 on January 17, 2016, 09:22:10 pm
Timing belt tensioner. Mine did this and I got it changed and looked at the old tensioner and when you turn it, it squeals /chirps.
Does it sound like tiny birds chirping?
Post by: bowkes7 on January 18, 2016, 10:08:41 am
yeah it does sound like little birds haha
not sure how long its been doing it, cant hear it in the car only when your outside. only discovered it when io turned the ignition on to warm the car whilst i was de - icing it.
thanks for your help
Post by: bowkes7 on January 18, 2016, 10:22:03 am
can i ask how much it cost to replace your tensioner
Post by: AJG09 on January 18, 2016, 12:20:25 pm
If your changing the tensioner then its belt off so Mayaswell do belt and water pump at the same time. I did this I think vw charge £420... I think!   :happy2:
Have a search on youtube for the noise First
