All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Markis236 on January 25, 2016, 07:24:00 pm
Title: Miss fire / engine management light !!
Post by: Markis236 on January 25, 2016, 07:24:00 pm
Ok guy this is my first post on the forum since I joined and unfortunately it's a problem !
So I got my self a mk5 golf gti (200ps) so the problem is I was driving home from work today and the car basically shat it's self ! Basically what I mean is it's now miss firing like f*ck ! Feels like the car is running on 2 cylinders with the engine management light flashing ! Pulled over and done some checked (oil and water) and I have no idear what the problem is ? I doe a coilpack recall on Friday but because I can't drive the car to vw they say I can't get the coilpacks unless a vw engineer fits them for warranty reasons ? I was wondering if anything else can cous this done some reading and it could be a few things #1 coilpacks #2 carbon deposits on inlet valves #3 bad plunges (changed 2000 miles ago) or #4 carbon deposits on the injector ? If any one else has had symptoms like this any info do would be great :)
Thanks Mark.
Title: Re: Miss fire / engine management light !!
Post by: Andy on January 25, 2016, 07:40:23 pm
Welcome to the forum,Sounds like coil packs what you described,if your in the aa etc get them to recover it
Post by: Markis236 on January 25, 2016, 08:07:09 pm
Thanks for the replay bud phoned a friend with a fault code reader going to find which cylinder is misfiring and try switch the coilpacks around and pray it's just a coil down miss my baby all ready haha
Post by: shoaybmakda on January 25, 2016, 10:49:30 pm
Had a similar issue and after replacing coil packs and spark plugs turned out was a injector on cylinder 2 missfire.
Post by: Markis236 on January 26, 2016, 06:49:22 am
Was luck it is clylender 4 coil down swapped it with 2 and it's now number 2 down so it's just a coil haha it's trying to get the car to vw on Friday for the coilpack recall its booked in for haha :signLOL:
Post by: anorganix on January 26, 2016, 07:45:09 am
If I were you, when changing the coils I'd also change the spark plugs.
A set of NGK BKR7EIX go for about £30.
