All Things Mk5 => Mk5 General Area => Topic started by: Nasir on January 31, 2016, 04:26:25 pm
Title: Yellow Sidelights in Xenon Headlights?
Post by: Nasir on January 31, 2016, 04:26:25 pm
As standard, the headlights come with a yellow sidelight bulb just underneath the dipped beam. I think it contrasts nicely with the white hue of the xenon beam and accentuates it somewhat. But I also think a white sidelight would make it look more modern perhaps?
Is this a yay or nay for you? Does the yellow look a little old? Or is the white LED a little played out?
What do you have on your xenon headlights?
Title: Re: Yellow Sidelights in Xenon Headlights?
Post by: An0NyMOUs on January 31, 2016, 04:48:13 pm
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FCrtr_G%2FMobile_Uploads%2FIMG_20160130_163528_zpsmovubuwt.jpg&hash=c0eacd340fc57139f2c176e2a8108aaa5dc1e0f5)
I have some Philips 'Ultra White' halogen bulbs because LED lights nearly always go wrong. I think I'll have to get some LED's though. Too yellow..
Sent from my Nexus 6 using Tapatalk
Post by: r5gtt on January 31, 2016, 06:28:50 pm
Both mine are amber as it'll not mix well having both white and amber under the main lights IMHO
I'd say turn the amber parkers off so they only indicate when needed and try some led side light white bulbs and see how they look.
Look in the forsale section as whooosh is selling bulbs and you can see what they look like in white xenon.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1374.photobucket.com%2Falbums%2Fag433%2FSandy1786%2FMobile%2520Uploads%2F2015-12-14%252016.42.48.jpg&hash=1e6984971238ea6cc5fdb7e42a707b1b5e4d696b)
Post by: john87 on February 01, 2016, 12:12:10 pm
I've just got the standard W5W's in, yellow as they come. I did have some leds in, but as is often the case with capless led bulbs, they often worked themselves loose enough to go out and cause a bulb out warning  :fighting:
Post by: Matto on February 01, 2016, 03:17:28 pm
This was mine running LED sidelights. While I liked the look of it, I was fed up with them keep failing. Seems to be common with LED's so I changed them for amber W5W's instead. I now have the full orange strip with dimmed indicators. No photo of those at the mo.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FMatt.H%2FInternet%2F97_zpsiambq1la.jpg&hash=860c72fb6ea5889875e3d3556ee92d0ea70b744f)
Post by: FJ1000 on February 01, 2016, 03:26:13 pm
Standard sidelight vs. LED:
(https://farm1.staticflickr.com/637/20363648084_65beb715c4_z.jpg)
With xenons on (bulbs swapped for 600K Morimoto bulbs)
(https://farm1.staticflickr.com/658/20976430582_18236a5dc0_z.jpg)
Sidelights and xenons sourced from EM Tuning (forum sponsor on RS246 and Audisport). No errors or problems of any kind. I use bulbs from EM tuning on my other car too.
Post by: tlnds on February 01, 2016, 03:28:12 pm
I have done same as Matto above
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1084.photobucket.com%2Falbums%2Fj420%2Ftomlindsell%2F4d22b7cd-8447-41fe-b2b0-5ac23f5d07a4_zpsiutiobah.jpg&hash=b65fcd66476e69adb34984dfbaa708c5438868ba)
Post by: v4rley on February 01, 2016, 03:58:30 pm
@Matto (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=4512)  @tlnds (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=12033)
How do you find them with regards to indicating? Have considered doing the full Amber for a while but concerned about confusion when indicating as the obviously only the Amber of the indicator flashes..
Post by: r5gtt on February 01, 2016, 04:03:06 pm
Stick with amber side lights as you don't want to be messing around with bulbs all the time.
The centre ones are not amber. it's the lense in front of the bulb that gives the amber indicator effect. the side lights are clear but you can fit amber bulbs in to complete the amber lower EU look  :happy2:
Post by: tlnds on February 01, 2016, 04:07:30 pm
When you indicate it stops running at the brightness you have set, and flashes on and off as normal. Then when you stop indicating it quickly goes back to reduced brightness.
Post by: Matto on February 01, 2016, 04:10:18 pm
Tlnds is correct. I only have mine set at 2% so not very bright at all. Never had anyone get confused with them. The only time I found that was when I was when I had cornering fogs enabled. Specifically at islands. As you turned left to enter the island the left fog would come on and people would think it was an indicator and would go to pull out. Since tuning them off I have had no issues.
Post by: v4rley on February 01, 2016, 04:20:48 pm
I know how the running lights work, my question was more about the sidelights running the same amber colour as the indicators, so when indicating only the inner (indicator) part of the amber part of the light would flash leaving the outer (sidelight) still a solid amber colour.
Post by: tlnds on February 01, 2016, 04:32:01 pm
I don't think it adds much confusion I think its still pretty obvious that you are indicating (as far as I can tell as I'm sat in the car). I haven't had any issues so far although I've only had this setup for a few weeks.
Post by: Matto on February 01, 2016, 04:32:33 pm
You wanted to know if they caused confusion. I confirmed they didn't and gave an example of when I have experienced confusion from other road users.
Post by: r5gtt on February 01, 2016, 09:12:20 pm
That he did  :signLOL:
Post by: r5gtt on February 01, 2016, 09:17:36 pm
That is correct amber will blink a brighter and then reduce in brightness when it stops blinking. Outer side lights will remain solid amber or white or which ever colour you fit in.
Post by: Reubs1983 on December 13, 2017, 12:25:49 pm
Hi i am looking to do this with my car,
i have been told that i need to get a code for it so the garage can load it to the car.
Is this true?
If so has anyone got it?
Post by: r5gtt on December 14, 2017, 03:28:12 pm
Is this true?
You just need someone to code them in on vcds vagcom by ticking a check box and also turning bi xenons without shutters so not to blow your wiper motor.  :happy2:
