All Things Mk5 => How to Guides / Troubleshooting => Topic started by: stuupnorth on February 02, 2016, 07:48:34 pm
Title: fault code
Post by: stuupnorth on February 02, 2016, 07:48:34 pm
Hi all
just had my car scanned (cheers Ric) after yellow engine light appeared although the car runs ok
and a few fault codes came up
Tuesday,02,February,2016,18:30:18:30570
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0
Data version: 20140905
VIN: WVWZZZ1KZ6W008936   License Plate: STUART2
Mileage: 208700km-129680mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56
VIN: WVWZZZ1KZ6W008936   Mileage: 208700km/129680miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Not registered 0001
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2159747
   Coding: 040300031C070060
   Shop #: WSC 00835 210 81320
   VCID: 24419CD2E7AC953EDF5-8071
3 Faults Found:
005425 - Camshaft Timing Adjustment
               P1531 - 004 - Open Circuit - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100100
                    Fault Priority: 0
                    Fault Frequency: 23
                    Reset counter: 255
                    Mileage: 208585 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:11:32
             Freeze Frame:
                    RPM: 1432 /min
                    Load: 24.3 %
                    Speed: 0.0 km/h
                    Temperature: 3.0°C
                    Temperature: 3.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.430 V
000818 - Knock Sensor 2 (G66)
               P0332 - 002 - Signal too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 208612 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:35:37
             Freeze Frame:
                    RPM: 2726 /min
                    Load: 48.2 %
                    Speed: 109.0 km/h
                    Temperature: 42.0°C
                    Temperature: 4.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 14.732 V
000017 - Bank 1: Camshaft A (Intake)
               P0011 - 004 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 208651 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:15:19
             Freeze Frame:
                    RPM: 2005 /min
                    Load: 32.5 %
                    Speed: 80.0 km/h
                    Temperature: 59.0°C
                    Temperature: 7.0°C
                    Voltage: 14.351 V
Readiness: 0000 0100
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 042 Q    HW: 02E 927 770 AD
   Component: GSG DSG         070 0925
   Revision: 04507000    Serial number: 00000505130668
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 214F95C6F8BE8016B43-8074
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   VCID: 4089304213F4A91EDBD-8015
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 68D9C8E25B04B15E33D-803D
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
            000 - - - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000001877885
   Coding: E58D0F2700041800001400001400000000097F005C
   VCID: 2B5377EE8A725A461EF-807E
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 01279
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 01279
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0EH5SG
   Coding: 0012870
   VCID: 377B5B9E463AEEA66A7-8062
   Subsystem 1 - Serial number: 6332MSME0A130371$
   Subsystem 2 - Serial number: 6342MSME0A127847B
   Subsystem 3 - Serial number: 6351HSME076608284
   Subsystem 4 - Serial number: 6361HSME074F19004
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012112
   VCID: 77FB9B9E06BA2EA6AA7-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           007 0050
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0001403
   Shop #: WSC 00864 210 91883
   VCID: EED53EFAF9E0EF6EF91-80BB
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 191210F2000258
   Coding: 3F0001
   Shop #: WSC 00787 210 95039
   VCID: 306960826354399E2BD-8065
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 208701 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:27:16
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1012
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669452704
   Coding: 010000
   Shop #: WSC 00028 028 00001
   VCID: 285988E25B84715EF3D-807D
1 Fault Found:
03138 - Input AUX IN
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 175
                    Mileage: 208701 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:29:08
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 A
   Component: RNS-MID       H04 2720
   Revision: AB001001    Serial number: VWZ6Z7H6093068
   Coding: 0E000400040000900020
   Shop #: WSC 05314 123 12345
   VCID: 2E557EFA79602F6E391-807B
1 Fault Found:
00857 - CD Changer Unit (R41)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 208696 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:29:17
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2310
   Coding: 0000628
   Shop #: WSC 00864 210 17480
   VCID: 3665569A413017AE711-8063
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 33636F8E5242028656F-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 00D802087F2D850DC85AC69010CC
   Shop #: WSC 12345 785 00200
   VCID: 78F998A20BA421DEA3D-802D
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
2 Faults Found:
01134 - Alarm Horn (H12)
            000 - -
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000628
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 2
                    Reset counter: 174
                    Mileage: 208696 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:29:17
End   ---------------------------------------------------------------------
any help would be great
Stu
Title: Re: fault code
Post by: doylebros on February 02, 2016, 08:52:11 pm
Look at this http://wiki.ross-tech.com/wiki/index.php/17939/P1531/005425
The valve in question in the link has a history of people breaking the electrical connector - check there before spending any money.
