All Things Mk5 => Performance Modifications => Modifications & Technical Area => R-Tech Zone => Topic started by: Lewo on February 08, 2016, 11:16:58 pm
To be Honest even though I've only had the car for 3 months and love it in bog standard form, having read some threads on here it's got me thinking of having it done spring/summer time.
Got loads of questions about this but just a couple for now....
I've read that there seems to be 40-50 HP more but how do you feel the difference in driving terms?
Is it just at the higher revs you notice it or does it pull better at lower revs too?
Also is it worth/necessary getting the DSG box done as well, what difference should I expect?
I read on the other threads about getting a couple of bits on the engine checked beforehand so no doubt I'll be asking about that later on too. :laugh:
Don't think. Just do it :happy2:
But please make sure the car is in good condition. Some just want power but don't even maintain their car properly.
Have a read of this thread, it should answer all your questions:
http://www.mk5golfgti.co.uk/forum/index.php?topic=95964.msg954509.msg#954509
Stage 1 transforms the car - get it booked!
best thing I've done to my car was do a stage 1 r-tech. There is a huge difference and you will notice right away. maybe you get around 40-50bhp gain but on torque you get around 100lbsft gain. Go for it.
Yep. I often wonder how I got by on a standard map. Only problem is, once you've been on Stage 1 for a bit you get used to the power, and want more and more. It never ends!
So true. But I can't justify spending another 2k or more on a 10 year old car to squeeze more power out of it. That's why I'm selling and moving on. Plus I can't imagine a stage 3 would be good on a fwd the stage 1 is the max for a fwd and even with that soo much wheel spin goes crazy when you try a nice launch from the lights.
The trick is to avoid launching the **** out of it at the lights and enjoy the torque in 3rd and 4th on the roll. And for me, there's plenty in that respect that can be improved from Stage 1. Mine peaks at 296lb/ft quite early, but then drops off quickly due to stock hardware. This will soon change..
lol ye thanks I know how to go off the lights without the wheel spin. Even in 3rd gear you get some spin at least on the dsg cant comment for the manual. Either way well worth the £290 I paid for stage 1 I don't know how much it goes for these days. Good luck.
Defo get it done..I'm only stage 1 with 310bhp and don't want any more power and it's been a few months since the map and I'm used to it now. There are 5 selectable maps with the rtech one I have so you can change the power/curve based on the conditions on the road. Any more than 300bhp in a fwd car is a waste imo unless you start going down the LSD route or 4wd.
Feels masively faster, more responsive and also you get free traction control mapping from R-Tech (and switchable mapping as said above).
Do pre-cat delete to get a few more cheap horses :happy2: http://www.mk5golfgti.co.uk/forum/index.php?topic=41083.0
Just get it booked :happy2:
Dave
Cheers all, not surprised with the 'get it done' replies just need some more info first.
Have read that thread AJP ta.
So you get more torque as well which is probably of more use to me.
Just need to know about the DSG remap and the difference with that or if it's needed or not ta.
I'm completely useless with mechanics so the pre cat wont be done, maybe the panel filter will :smiley:
Ok, so I'm useless too, so I paid to have it done. Can't remember the cost but I know Alex at AKS charges about £100 for it. Definitely worth doing.
I planned mine for ages and finally had it done at the end of last month. The car is fantastic. Same advice as @Peskyjones (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=11854) , dsg remap not required.
With precat delete and a Ramair CAI, I was pushing 210bhp and 236ft/lb torque. After map, I was at 257 and 306. Power is so much more usable now and Sport mode in ocular is transformed, with power now available higher up the rev range.
The lads are fantastic as well!
Dave
Just a thought... Dynodaze next to r-tech may be able to do the precat for you before map if you time it right?
Dave
Definitely worth getting the pre-cat knocked out. It's proven to work, maybe not to the extent of an all singing and dancing turbo-back exhaust, but for the cost of getting it done it's a no-brainer.
Anything to free up some flow after the turbo is a good thing.
Cheers pesky good to know.
Maybe I'll give them a ring too.
That's exceptional for a bone stock stage 1. You sure the last owner didn't leave an uprated pump in there and forget to mention it..?!
On average, cars with the pre cat delete make better torque, for longer, with stage 1. It's as much about the area under the curve as it is peak figures. Wonder what yours would have made with a pre-cat delete...
Great result for stock hardware that though.
So daves with pre cat delete and ramair made 257bhp and 306ftlb
Mine completely stock made 254bhp and 332ftlb :confused:
Nobody likes a show off
Haha and no one likes a saw loser :wink: to be honest, I wasn't showing off - just questioning the proof that induction and pre-cat delete will yield more power. As AJP has said, perhaps mine is a one off. I've seen more cars that are stock that have yielded more power then mine
Mine with pre-cat delete and panel filter made 268bhp and 334lbft with just the addition of a BCS cat back at stage 1 with R-TECH.
I had a bluefin fitted previous and on the same setup that run 242 and 266.
Just for some comparisons.
All booked in for a months time :smiley:
Was thinking about getting a pipercross panel filter but seen http://www.pipercross.net/pipercross-performance-induction-system-pk322_p24037922.htm (http://www.pipercross.net/pipercross-performance-induction-system-pk322_p24037922.htm) too.
I want to keep the engine cover so wondered if you get much extra performance to make the extra £60 worth it?
That is a total utter waste of time and money!
Either get a drop in panel filter for less than £30, or get a proper intake
Great news that you got it booked, you won't regret it.
As said above, wouldn't bother with that kit. A drop in one will be fine.
Dave
Okey doke point taken. :wink:
Which filter have you seen for less than £30 Dan, are they all pretty much the same?
Think I've read somewhere on here not to oil it as it messes up something or other?
Bleedin work getting in the way of fun..... :mad: Mapping put back a couple of weeks now :sad1:
Well, it was worth the wait.
249. something bhp!
Thanks again Niki and guys, worth the 3.5hrs drive oop north! :jumpmove:
