All Things Mk5 => Mk5 General Area => Topic started by: Hannakournikova on February 13, 2016, 04:35:19 pm
Title: ABS Pump G201 fault - cross compatibility with other VW models
Post by: Hannakournikova on February 13, 2016, 04:35:19 pm
So the amber traction warning appeared on the dash. Fault codes checked and confirmed as G210 fault.
VW have stopped covering this repair under a good will gesture.
I have been offered one from a 2007 Passat PN - 3CO 614 109 K
My PN is 1KO 614 517 AF
Any advice?
Title: Re: ABS Pump G201 fault - cross compatibility with other VW models
Post by: Frodo-anni on February 13, 2016, 04:45:37 pm
Just had the exact fault on our Leon, Seat were having none of it. VW confirmed they stop goodwill on this issue last year, regardless of age/miles/history etc....
Have fitted the repair kit, which is basically all the internals of the abs pump changed, this was £280 + fitting, came in at £460. Ended with more discount after MOT, service, cam belt & waterpump.
Post by: Hannakournikova on February 13, 2016, 04:54:21 pm
Thanks Frodo. I'm able to source the repair kit for £170 so thats an option but wondering if the passat pump listed above would work as i have been offered it free.
