		All Things Mk5 => Mk5 General Area => Topic started by: edition_30 on January 06, 2010, 08:17:06 pm
				I’m thinking of going to vw to see if they will reflash my car with oem map...  originally i thought i may have had a little clutch slip but that seems not to be the case now as it’s happening too low down the rev range (1.3 - 2k rpm).
Do I simply just ask for an ecu update?
Also does the ecu log a date when a new map is applied?
				I think you have to pay £ 60 or so for a fault diagnosis, or reflash  :happy2:
				thanks mate.. im getting a service done next month.. do you think it would be included in the service.. also do you think they may ask questions into why i want the ecu re flashed.. im kinda hoping i can get extended warranty on the car
				They should defo reflash in the service, you could just make up a little fault so they would check at that time.
I would wait until then. Do you not know anyone near you  with a select + switch who can put revo's stock settings back on to see if that cures it while your waiting for the service. :happy2:
				not sure mate.. will start a thread.. in terms of issues any ideas what i could suggest?
				You could just say the exhaust light came on.  :happy2:
Have you had a look in the VCDS area of the forum for people with select switches near you.
				Where abouts are you located mate?
				In Hertfordshire.. north London.. near Enfield..U?
				mate im in Waltham Abbey.. wat dealer u going to take it 2?
				was thinking about using Harlow.. or possibly loughton..
dont suppose u have a revo switch?
				sorry mate i havent gt a switch..
my mtae is head tech at south ruislipe and if u want anything sorted hes your man and just sort him out a drink.. he does mine and a few other mtes of mine..
He done sum things for me under warrenty even tho its modified.
iv had very bad expierence with loughton.
				If you could put me in touch mate then i would well appreciate it.. what happened @ loughton?
				il speak 2 him later and il pm u his number and then u can sort it with him..
I bought the car from there from new..
iv had problems with the engine cover braackets snaping twice and engine mouts being replaced never got it sorted until i gt introduced to my m8 whos the technician who sorted it.
				Thanks mate.. really appreciate this..
