All Things Mk5 => Mk5 General Area => Topic started by: Nasir on February 28, 2016, 05:44:40 pm
Title: Steering Angle Sensor Fault
Post by: Nasir on February 28, 2016, 05:44:40 pm
I'm running out of ideas on this one. I've had the steering angle sensor changed, reset with VCDS multiple times, 4 wheel alignment done - but it hasn't worked. Fault code is 00778-000 Intermittent.
When I'm driving the steering wheel, ESP and Tyre pressure lights come on intermittently. The steering wheel light comes on and off constantly for a few minutes as you turn the wheel.  The ESP and Tyre Pressure lights stay on and turn off after a few hundred metres. They often return 6 or 7 times in one instance. After this, it may not come on for a day or so. Or it could return within minutes.
In VCDS measuring blocks, when the light comes on the steering angle sensor freezes. It also say the steering angle sensor is not initialised. Now, it also says the sensor is defective (intermittent). But the sensor is a new one from VW.
Would really appreciate some help on this. I'm at my wit's end with this.
