All Things Mk5 => Mk5 General Area => Topic started by: kierhanlon6 on April 10, 2016, 08:44:54 pm
hello my rear wiper motor keeps getting suck at random points of the wipe is this a easy fix or a whole new motor? any help please cheers
The most likely fault is the wiring in the tail gate flexi connectors at the top - the problem is there are different levels of repair
http://www.mk5golfgti.co.uk/forum/index.php?topic=86689.0
New harness expensive but little in the way of tools required
Or
Cut out broken/failed section solder in new and retape into existing harness - cost very little if you have access to the required tooling?
Or
cheers for the response. where is the most common are just in the flexi that meets the body to the boot?
Yes but be careful since the wires for the wiper are all White coloured ones and if broken you'll have to do a bit investigative work to match them up for repair.
ah perfect thanks for the help will try and pull the rubber back to expose the wires hope it will be easy enough
