All Things Mk5 => Mk5 General Area => Topic started by: pudding on May 09, 2016, 11:35:54 am
What do you guys do about switching from the O-ring / clip connections on your boost pipes to hose clamp style?
Anyone tried this kit? http://www.bar-tek-tuning.com/lshop,showdetail,1755,en,1462805937-3367,schlauchkits,21tf060,12,Tshowrub--schlauchkits,.htm
Have seen some people modify the standard or upgraded pipe, they cut of the bayonette fitting and weld on a stand pipe connection. See here for example:
https://www.instagram.com/p/5SUUDKTOtC/?hl=en
Nice one! I did have that in mind as a cheap mod onto the standard discharge pipe, but I can't weld ally! I'd need something plug & play for an easy life!
