All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: phatedition30 on May 30, 2016, 04:49:17 pm
I have had a new rns510 fitted to my car with a 76p Bluetooth module,the Bluetooth works fine when making calls,the problem is when I try to stream music I'm not getting any sound!any ideas on what it could be?
Also should my headunit be showing bt audio?
Yes... when you press the media button you should have somethink like...
HDD SD BT
along the top.
Mine isn't showing bt!Does that mean I have been sold a module that doesn't support music streaming?
Check the RNS-510 menus definitions. You might have not activated the BT streaming or something.
Whats the part number?
First of all check the head unit settings to enable BT Audio then when on media screen, if bt is on top right corner make sure your playing music via phone then Bt will light up so you can press it.
