All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Scoobykiller on June 03, 2016, 11:46:33 am
Posted about heater not working few days ago
Here is what it shows on vagcom
Any ideas(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fhaaris1971%2FMobile_Uploads%2FCAB582C6-E8CB-426B-81F2-79AB0F5BE726_zpsmnwmvhca.jpg&hash=00370c641b2618bdf0af7d708fb1d1187b2f465a)
Your G65 sensor has probably failed
Part number - 1K0-959-126-A
P00576 can be any number of things
http://wiki.ross-tech.com/wiki/index.php/00576
Where does the sensor go and would it cause the heater to not work
Sensor sits in front and just slightly below auxiliary - See latest update http://www.mk5golfgti.co.uk/forum/index.php/topic,89715.msg907250.html#msg907250
I don't think that would affect the heater though I'm afraid....
i have a complete heater box if you need any parts :happy2:
Dude how many different posts on this subject have you posted?. :signLOL:
Again take the blower out and check it. could even be the heater resistor.
G65 is the air con switch/sensor outside the car in front of the alternator.
My gti has clumate control so blower will be differenr??
Does the climate control gti share same resistor as normal blower non climate control?
Yes it does as I don't recall seeing a second blower and can hear mine blow faster and slower when con on and off.
