All Things Mk5 => Mk5 General Area => Topic started by: Mikkel on June 14, 2016, 03:23:05 pm
Title: Edition 30 Stuttering >6.000 RPM full throttle
Post by: Mikkel on June 14, 2016, 03:23:05 pm
Hey guys im a proud owner of an edition 30. But lately my car has been acting strange.
Whenever i try to pull full throttle in 3/4/5/6 gear, it starts stuttering after ~6.000 RPM. If i keep the thorttle on it will keep stuttering untill it eventually shifts, and it will start acting up again after  6.000 RPM.
I've pulled some fault codes:
First day:
P1093 - Bank 1; Fuel Measuring System 2: Malfunction
P119A - Fuel Pressure Sensor (G247) : Malfunction
Second day:
P0300 - Random/Multiple Cylinder Misfire Detected
P0304 - Cylinder 4 Misfire Detected
P0302 - Cylinder 2 Misfire Detected
Because of the fuel faults, i checked the cam follower as i read it can cause many problems. On the inside i can feel the little circle where the fuel pump pushes, is that a problem? Some pictures:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi63.tinypic.com%2F1zd5fdf.jpg&hash=ec8c371ef0e96f56c67ede36442e7618f5e96791)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi63.tinypic.com%2F15ykvd.jpg&hash=2612dca7a4354aab5bfa1e8255ca1753478278d1)
As i dont have VCDS anymore, i tried to do some logging with my autocom device:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi67.tinypic.com%2F2vb0xo8.jpg&hash=b1518d4429ada2ca5f12302934a25b9588e84aa3)
Group 31: Lambda.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi68.tinypic.com%2F2ly38uq.jpg&hash=75020a5ba4f863314f13d1db7c03c82fc5b2d261)
Group 231: LPFP
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi66.tinypic.com%2Ffwompx.jpg&hash=42f6337982e6aac781dfe6675b1475a043b39585)
Group 230: HPFP
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi65.tinypic.com%2F2ltqamw.jpg&hash=3cb2d9bf99f06f9dfd63a28b4e6edb4089d2d5e5)
The car is modified and has a bout 385HP / 480Nm, I believe it has an autotech fuel pump (or upgrade), RS4 injectors, FMIC, full exhaust system no cat, K&N Typhoon air intake.
I noticed that the fuel pressure is pretty high at 190bar? Or could it just be as simple as a pair of spark plugs + coils?
Please some thoughts  :thinking:
Title: Re: Edition 30 Stuttering >6.000 RPM full throttle
Post by: Mikkel on June 15, 2016, 09:34:05 am
How is it possible that the ecu requests 190 bar?
