All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: Madone on June 19, 2016, 03:30:35 pm
Title: Thinking about water/meth install
Post by: Madone on June 19, 2016, 03:30:35 pm
Decided to see if I could put some more timing into my Revo stage 2+ edition 30, it as setup by a tuner but thought I would run some logs and go 1 higher on the timing. As expected the timing pull was higher than I would like so gone back to the numbers set by the tuner. Nice to see they did it properly anyway  :laugh:
To get that extra timing I am thinking water/meth injection. What is the verdict. @Dan_FR (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=9513) , hopefully you can chip in here.
Do most people use Devilsown?, they state most people use the washer fluid tank ?, how long does it last before a refil is due ?
Dan, I think you are running timing 9 ??, that's epic, I went from 6 to 7 and got too much pull.
How hard is the fitting ?, Devils do a VAG kit which runs from the standard MAF sensor I think ?, and is a progressive system ?
Title: Re: Thinking about water/meth install
Post by: Dan_FR on June 19, 2016, 04:02:55 pm
I use the washer tank. I usually top it up weekly out of habit when checking the oil but it would probably last a month  (circa 600 miles) before topping up.
Ran T9 through the winter with hardly any (or no) correction for most of the rev range. Dropped it to 8 as the temps increased and the timing pull is zero once the meth kicks in. Might leave it like that happy in the knowledge that it's safe, I've also leaned the mixture out a little too as I was running it pretty rich to compensate. Previously ran t6 with smallish amounts of correction.
I run the most basic  devil's own kit which uses a simple boost activated switch. Granted it's on/off but it does the job very nicely with the added benefit of not having to run ANY wiring or pipework in to the car. Everything is contained within the engine bay which made fitting very simple.
Worth doing. Really does make a huge difference when running a proper 50/50 mix with pure methanol (not using screenwash)
Post by: Madone on June 19, 2016, 04:51:50 pm
Where and how do you plumb the water nozzle ?
I am seriously tempted, even driving my car with timing 7 and it being pulled back it felt fantastic !
Is it easy to setup ?, I read you can adjust the activation pressure it injects at ?, just a case of logging and moving that point ?
Post by: Dan_FR on June 19, 2016, 05:53:42 pm
I have an AKS throttle body spacer. Uprated charge pipes often have the boss needed for the nozzle.
Very easy. Mine is set up to inject very early, you can either temporarily wire up an LED indicator (crudely running it in to the car) or do it solely from the logs. Easy to tell when injecting as the difference to the IAT is huge.
Difference is huge, and I see my timing in the low 20's by 6k rpm so it's happy with lots of it. My favourite power mod to date with the biggest impact £ for buck (excluding stage 1 remap of course).
Post by: Madone on June 19, 2016, 06:45:06 pm
Thanks mate
So what would be my best option to mount the injector ?, where did you tap off for the pressure sensor ?
I def like the idea, would be a massive gain to run more timing. I guess a progressive system means you can use less water overall and ramp up delivery ?
Can you use a meth water mix ?, is there a min ratio ?
Cheers mate
Post by: Dan_FR on June 20, 2016, 05:42:33 am
I'm happy with the TB spacer, so unless you already already have a charge pipe from Revo, CTS etc. I'd get one from AKS  (do not buy the cheaper Creation motorsport imitation as it's sh*t)
For the boost pressure feed, I have a manifold blank from a PCV delete kit ( I run a full vent to atmosphere setup very similar to the R-Tech kit). It blanks the side of the inlet manifold but comes with either a nipple or blank to give a boost feed. The AKS spacer is around 85 quid and the inlet manifold blank around 40.
Progressive just allows you to run something like 35% flow at x psi, which then switches to 100% at y psi, both boost pressures adjustable on the controller. But this will involve extra wiring and installing inside the car.
Run a proper 50:50 mix with pure methanol and deionised water. You can still use it to clean the windscreen if need be as it does the job (a lot of screenwash fluid contains methanol). If you can't find a local supplier then methanol can be bought for 30-40 quid for 25 litres on eBay delivered. Deionised water is widely available but cheapest I've found is delivered by eurocarparts.com. 25 litres of each lasts me over 12 months
Post by: Madone on June 20, 2016, 09:49:12 am
I did read that with these systems there is some potential danger if you hit the rev limiter as the fuel gets cut by the ecu but the water doesn't, hence a really lean mixture and potential damage. Seems some more expensive systems monitor fuel (via an injector) and cut the water if the fuel is cut ?
Post by: Dan_FR on June 20, 2016, 04:01:00 pm
It depends on how the ecu works and is set up. The standard soft limiter pulls back as you approach it rather than be a violent cut of the fuel and/or spark so you would never be in that situation.
To be honest I've not even heard of a system that advanced, nor heard of anyone using it so it's not something good I would worry about
Post by: Madone on June 20, 2016, 04:07:03 pm
Looks like Aquamist sell systems that monitor multiple engine inputs.
http://www.aquamist-direct.com/806-063-hfs3-v3-1-system-a-truly-progressive-system-utilising-pwm-valve/
Not sure if they are all needed
Post by: ReDBull on June 20, 2016, 04:13:26 pm
I've just bought a AEM kit. I need to look at how to install it now.
Post by: Madone on June 20, 2016, 04:18:19 pm
What sort of kit are you going for ?
