All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: GTIEagles on June 21, 2016, 09:59:59 pm
Title: Disable built in aerials with VCDS?
Post by: GTIEagles on June 21, 2016, 09:59:59 pm
My car has had an aftermarket shark fin dab aerial installed by the previous owner. The aerial seems to work fine however I'm getting these two fault codes on VCDS under the radio section.
2 Faults Found:
00856 - Radio Antenna
            011 - Open Circuit
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit
I'm guessing this is due to the built in diversity aerials no longer being used? If so is there anyway to disable the aerial in VCDS?
Title: Re: Disable built in aerials with VCDS?
Post by: ady-uk on June 22, 2016, 08:17:23 am
Diversity box in under drivers seat......
Buy two Fakra cables on ebay.
unplug two input leads and two output leads from box and then join them up using bought cables.
Can unplug power cable at same time....job done and you'll have proper aerial feed to radio
Post by: GTIEagles on August 03, 2016, 08:43:19 am
@ady-uk (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=11026) sorry I completely forgot to check this post. So if I buy two of these cables https://www.ebay.co.uk/itm/331564937972 to join them and bypass the diversity box it should remove the error code?
