All Things Mk5 => How to Guides / Troubleshooting => Topic started by: ChazGTI on July 04, 2016, 11:31:33 am
Title: New Flywheel and Clutch, can't get into gear.
Post by: ChazGTI on July 04, 2016, 11:31:33 am
Dual Mass Flywheel had been slowly failing until it sounded like it was a box of gravel, so thought it was best to get on and replace it (118k, been stage 1 for last 20k).
Ordered the (I believe stock) LUK DMF as well as a new Clutch and Throw-out Bearing as these couldn't have been far behind. I was right about the clutch(almost no meat left on it), TOB peace of mind either way.
The job was a real pain in the ass when it came to dropping the transmission and also getting it back in there, but everything went smoothly overall. (Had another mechanically minded mate helping me the second half of the job.
Got everything back together, hydraulics power bled, shift cables back on etc and checked gears before starting her up. All gears easy shifted, (with and without clutch pressed, engine off). Same on ignition too. But once engine is started, I can't get into any gears. I can shift into them about 1/3 way, then there's just a massive force stopping it, exactly the same every gear. NO CRUNCHING or any scary sounds though.
I can feel the engine change tone as if it's reaching a bite point when trying to shift? That's the best I can explain it without a video (can get one up).
I have to say that the idle is noisier than it was before and there is a vibration there that wasn't before. (Can get a video of this if needed too.)
If I start in gear (clutch up and also clutch pressed???) she does lurch forward and backwards in the relevant gears.
Now I did the clutch disc alignment by eye, but I've been assured that can't be the issue as the transmission wouldn't have gone back on otherwise (we confirmed the spindle was engaging the flywheel before tightening the transmission up too by manually turning over from the lower pulley on the other side of the engine.)
The DMF only goes on one way and I used thread lock on its bolts and also the pressure plate's bolts. Clutch disc was put in flat side to the flywheel as it should be.
So what I am taking away from this is that the clutch is fully engaged and will not disengage the flywheel enough (or even at all?) to change gears.
I can't find any special way of bleeding the Throw-out Bearing, surely that's the culprit here? Or have I messed up something else?
Title: Re: New Flywheel and Clutch, can't get into gear.
Post by: xjay1337 on July 04, 2016, 12:03:42 pm
I had that issue once. The clutch supplied was incorrect when assembled the height was wrong so the clutch wouldn't disengage.
Post by: ChazGTI on July 04, 2016, 09:06:24 pm
Thanks for the reply! Well it's definitely the correct gear, same stuff as from factory and visually identical too. Matched down to my engine code (AXX) etc.
Post by: r5gtt on July 04, 2016, 09:56:55 pm
Sounds like it's not been bled properly.
Post by: ChazGTI on July 05, 2016, 12:36:06 am
I've used a gunson's ezibleed from the reservoir down to the bleed valve that connects to the transmission. Done it twice now.
Can't find any special way to bleed the Throw-out Bearing, do you know if there is a special way?
Post by: r5gtt on July 05, 2016, 12:52:02 am
Are you pumping the pedal slightly not all the way down but let's say half way whilst the easy bleeder does its job?. Make sure you have the fluid topped up all the way to the rim as I made thay mistake once and lost all hope until my neighbour told me the reservoir is half empty?.
If you want to bleed the release bearing you'll want to submerge the pipe into a bottle of BF ans get someone to pump the pedal slowly and few times untill you see no more bubble from the pipe and then lock the bleed nipple and hopefully get the clutch working again.
Post by: ChazGTI on July 05, 2016, 12:59:51 am
OK I'll give that a try tomorrow! Thanks for the tip  :happy2:
Post by: r5gtt on July 05, 2016, 01:01:31 am
Let us know  :happy2:
time to Zzzz  :doh:
Post by: ChazGTI on July 05, 2016, 12:01:15 pm
Well doing the bearing bleed method only seems to introduce air into the system? We've done it nice and slow, but lots bubbles come out of the line into the brake fluid bottle every press of the pedal. They never stop coming and then once we try closing the system the pedal won't return by itself.
Power bleeding after this brings tons of bubbles out of the system after doing that.
Either way, it hasn't made a difference. I'll try again just to rule it out though.
Don't know what else to try.
Post by: r5gtt on July 05, 2016, 01:14:10 pm
There's something not right as the bubbles should clear them selves. Can't remember or even know how many reservoirs are there on the gti?. are they combined in to one for both clutch and brake?.
Post by: ChazGTI on July 05, 2016, 03:35:14 pm
Gonna take the bleed block off and inject the throwout bearing manually, then bleed again.  Want to make sure it's not full of air.  Might try a reverse power bleed too.  Yes, brakes and clutch share a reservoir.
Post by: r5gtt on July 05, 2016, 06:27:10 pm
Have you tried a gravity bleed where you let it rin naturally for a few nitunes making sure you tip up to the brim of the fluid bottle and then tightening the nipple and pumping the clutch pedal a few times and if the pedal doesn't raise itself manually pull it up and try again.
When you replace the master cylinder the procedure is different from just normal bleeding because normally people don't zip tie the line in an upright position and they let it dangle down dripping fluid out and filling the system with air. Or they don't cap the line from the brake fluid reservoir and the fluid level drops below minimum introducing air into the clutch master cylinder. Either way if it's not done correctly and you get air in the clutch, it can be difficult to remove.
Post by: ChazGTI on July 06, 2016, 06:15:24 pm
Gravity and Vaccum bled it,  no difference.
Disconnected starter motor to have a look inside and the pressure plate disengages and reengages fine with pedal!?
Really confused now.
Basically the difference of having the engine running stops the clutch from disengaging. I tightened the pressure plate bolts past the recommended 20nm,  could that be the issue here? I've got the access to loosen them.
I've also read that you're meant to realign the shifter cables whenever you disconnect them,  could this be the case even though i can shift all gears with the engine off?
Post by: GTI-MATT on July 06, 2016, 11:31:12 pm
Dont undo the clutch bolts that wont make any difference. If your 100% sure the parts are correct and you fitted the friction plate the right way round its got to be down to bleeding. I always gravity bleed it for a minute tighten nipple up pump the pedal 15-20 times then gravity bleed again and pump pedal again then final pressure bleed. Also you cant mix a match the makes of flywheel and clutch in your case they got to be both luk.
Post by: xjay1337 on July 06, 2016, 11:48:36 pm
As I said, I had the exact same issue, and the fingers on the pressure plate were not the correct height, so the clutch would not fully disengage when you pressed the clutch.
Are you sure everything is correct parts wise?
Do you have an LUK Flywheel with a LUK Pressure plate and LUK friction disc? Have you mis-matched parts?
If you have bled it (and you are sure it's done properly) then you have a parts or installation problem.
Post by: ChazGTI on July 06, 2016, 11:51:56 pm
Yeah i can't find anything about overtightened bolts having an effect, you must be right.
100% sure parts are correct,  all LUK and disc flat side against flywheel.
I did re-aligne the shift cables,  which did actually make my shifts a little bit smoother,  of course that's all though.
I guess I'll have a mega session of bleeding tomorrow then!
Post by: ChazGTI on July 06, 2016, 11:56:31 pm
100% LUK,  stamped on every piece.  Checked very thoroughly and really took my time to get installation correct. Gonna have one more big go at bleeding, then if still nothing I'll either drop the transmission again or tow it to a garage.
Post by: xjay1337 on July 06, 2016, 11:57:02 pm
Good luck man. Hope the bleed sorts it.
Post by: ChazGTI on July 07, 2016, 02:08:37 pm
Well I had two big bleeding sessions. Gravity bled, then pumped pedal 20 times, power bled. Then waited half an hour and repeated.
No change whatsoever.
Guess I'm gonna have to drop the transmission again, not sure what to actually look for though.
I'll triple check that the disc is the correct way around and that everything is still tightened to spec. What else can I check?
Slowly losing my mind with this now ugggh.
Post by: ChazGTI on July 07, 2016, 04:07:40 pm
Just thought I'd add some extra info in case it gives anyone an idea before I do the whole thing again.
With the engine running, if I try to select any gear without clutch up there is massive resistance (never actually tried doing that without a clutch, so I guess that's normal? Or wouldn't it start to crunch?) And trying to shift feels exactly the same no matter how far I push the clutch pedal down thereafter. So it feels like there is literally 0 difference across the entire pedal travel.
I've had the starter off and someone to push the clutch down and back up and I can physically see it working.
I would say the pressure plate moves on its dowels about 5-10mm?
Surely it doesn't need to move further than that to disengage?
Or should the pressure plate be totally static and only move within the forks? (Meaning I possibly haven't tightened the PP bolts up properly and what I'm seeing shouldn't actually be happening?)
Post by: xjay1337 on July 07, 2016, 04:24:41 pm
You overtightning the bolts wouldn't cause the issue.
I do strongly suspect the clutch kit is incorrect or fitted incorrectly.
Post by: r5gtt on July 07, 2016, 10:24:16 pm
I'm sure you cannot physically put the clutch plate on the opposite way round as it wouldn't go on.
Post by: ChazGTI on July 08, 2016, 08:07:34 am
Yeah I tested that with the old parts and it certainly is physically impossible to do that.
Today I'm going to unbolt the pressure plate through the starter hole, try and check that the disc is on the spline properly and then re-bolt, but this time to the torque spec.
Post by: Dan_FR on July 08, 2016, 08:43:49 am
The dowels are there to locate the clutch pressure plate, the pressure plate should not move up and down on the dowels if you have bolted the cover up correctly.
Post by: xjay1337 on July 08, 2016, 09:21:42 am
Depends on the clutch kit
Dansmith had it on his. Wouldn't go into first or reverse properly.
Post by: ChazGTI on July 08, 2016, 09:54:38 am
Right ok, so its likely that I've actually under-tightened the bolts?
Post by: r5gtt on July 08, 2016, 10:22:37 am
I've never on my miserable life torqued up clutch place bolts so please no one shoot  :fighting: me done for this as ive never ever ever had any issues and been working on cars for I've 20 years. I've also never seen anyone do the same even at dealerships  :signLOL:
I don't know how you'll see the disc on the spline without removing the box itself but I don't know, is there a way  :confused:
really xjay never seen this in my etire life and I've seen many performance clutches so he must have forced it on :confused:
Post by: Dan_FR on July 08, 2016, 12:28:23 pm
If the clutch pressure plate is moving up and down on the dowels in the flywheel, then yes the bolts are loose. It should not move from the flywheel at all once bolted up. All the movement/release of clutch is done in the 'middle bit '.
Post by: ChazGTI on July 08, 2016, 12:31:02 pm
Well as @Dan_FR (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=9513) had pointed out, I had under-tightened the PP bolts. Just finished slowly tightening them through the starter hole while a friend rotate the crank.
Tested the clutch and now the PP stays still like it should. Gonna put everything back together and HOPEFULLY all will be good.
Post by: Dan_FR on July 08, 2016, 12:34:04 pm
Keep us posted  :happy2:
Post by: r5gtt on July 08, 2016, 01:27:03 pm
Progress  :laugh:
Dont know how you managed to under tighten those bolts  :slap:
Post by: ChazGTI on July 08, 2016, 03:06:11 pm
All Sorted! Can't believe it was that.
Can't look over the basics!
Not sure how I managed to under tighten them that badly, but then again I didn't have a torque wrench that fitted the 12 point socket so I had to improvise.
Lesson learned!
Thank you all for the fantastic help and suggestions  :happy2:
Post by: Dan_FR on July 08, 2016, 03:31:35 pm
Great news. Hope they're tight enough now, big of thread lock is normally a good idea
Post by: xjay1337 on July 08, 2016, 05:11:42 pm
Result!!! :-)
Post by: ChazGTI on July 08, 2016, 06:02:21 pm
Yep used some loctite blue!
Man, the difference in a new clutch and flywheel after the state mine were in is so bloody nice!
Post by: TF51 AWD on October 27, 2025, 10:13:12 pm
Did you get to the bottom of this issue ive got the same problem with my twin plate clutch
Post by: mjmallia on October 29, 2025, 08:03:53 am
Answer is on the end of the second page.
