All Things Mk5 => Mk5 General Area => Topic started by: oisinc on July 19, 2016, 04:22:11 pm
Title: Which brand of water pump?
Post by: oisinc on July 19, 2016, 04:22:11 pm
I need to buy a water pump as the timing belt kit I have ordered is without one.
Which brand is best and should I look for metal impellers only?
TIA
Oisin
Title: Re: Which brand of water pump?
Post by: Chris92 on July 19, 2016, 06:44:17 pm
When I did my timing belt I order a hepo one from ecps and it had a metal impeller.
Post by: oisinc on July 19, 2016, 10:39:08 pm
Thanks  :happy2:
Ill make sure the one I have has a metal impeller. Ill prob go with Vaico. I believe their OE manufacturers.
Post by: Chris92 on July 19, 2016, 10:45:33 pm
Not a clue what brand vw use from the factory, every time I change one I either forget to look or can't see any stampings on it
Post by: Dan_FR on July 20, 2016, 07:38:15 am
Don't get one with a metal impeller. Manufacturers use plastic for a reason.
Buy genuine from VW, they are not that expensive on exchange for your old one. I've bought cheap on these engines and had to replace it as it leaked from new
Post by: flashp on July 20, 2016, 10:23:12 am
I'd echo this.
Keep up with correct servicing and you'll never have a problem.
Post by: Stupots on July 20, 2016, 11:24:53 am
I believe the reason is, if the metal impeller seizes, it will strip the cambelt... bad
Earlier plastic impellers were prone to disintegrating, but this hasn't been an issue for a while, so go plastic.
Post by: oisinc on July 20, 2016, 04:39:02 pm
ok thanks.. I thought the metal impeller was the preferred option.
Great info on here as always!  :happy2:
Post by: slimjimvw on August 04, 2016, 08:14:46 pm
Buy genuine,  not that expensive comparatively.
Sent from my D6603 using Tapatalk
