		All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Philly-GTI on July 30, 2016, 08:40:03 pm
				Hello,
 Currently in the process upgrading my RCD300 to a RCD510. My car is a 2007 Golf MK5 GTI.
 I already have a aeriel adapted which is needed qhen ugrading to newer units but what i am unsure about is if i need to upgrade my CAN GATEWAY or not?
 used my VCDS to find out what is currently fitted. Will i need to change my CAN gatway to not suffer the battery drain issues?
 Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
 Part No SW: 1K0 907 530 K    HW: 1K0 907 951
 Component: J533__Gateway   H04 0021
 Revision:   H04 02    Serial number: 010507F1001988
 Coding: 7F0F034007000001
 Shop #: WSC 01279 785 00200
 VCID: 2F6D7DC5BEAB3846D7-807A
 No fault code found.
 Cheers, Phil
				L or later to have the no drain issue :happy2:
				Cheers for reply. so i need a gateway then? if so wheres the best place to source one?
				If you want one precoded unit and sound advice so you can do the replacement yourself Eddie-NL will supply you with one.
 He's a member on here he may flash your original read this http://www.mk5golfgti.co.uk/forum/index.php/topic,96401.msg957142.html#msg957142
				thanks for advice
				Try with  the gateway "L" first as I have no drain with "K" :happy2:
				from what ive uploading from my vcds what gateway do i have? is mine a K?
 K, with 0021 software, which is not compatible, need to change.
