		All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: TheBlondeFella on August 06, 2016, 12:33:22 pm
				Hi
 So after many failed attempts to update my MDI software I've decided to ask for HELP!!
 I need the update for 2 reasons.
 1. the MDI won't recognise my iPhone 6s using either a USB or Lighting adaptor.
 2. the sound quality using an iPhone 4s via the MDI 30 pin adaptor is terrible
 Any one out there able to help?
 I have an RNS510 if that makes any difference ...
				I didn't think this existed until I saw this and a quick Google suggested otherwise!
 I was getting really bad sound too from my RNS and 30 pin connector until I stumbled across this thread and made the tweaks via VCDS and it made a significant improvement:
 http://www.my-gti.com/1411/volkswagen-rns-510-coding-when-installing-with-a-factory-amplifier
 Thanks, but as far as i'm aware i don't have a factory installed amplifier.
 General opinions are that an MDI software update will improve the sound quality.
 I believe I also require an MDI software update to operate the iPhone 6s.
				I remember reading years ago that you had to install each update in order but not sure how true that was. Also some newer firmware will not install on older hardware.
 http://www.my-gti.com/3148/volkswagen-media-device-interface-mdi-firmware-upgrades
