All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: Madone on August 08, 2016, 05:14:25 pm
Do many people change the pipe that runs to the throttle body, a few people have a CTS version, is this a worthy upgrade ?
if your trying to get the most from your setup then yes.
Also buy the turbo outlet replacement pipe too. the OEM one is tiny
Who makes those pipes ?, I think forge do some ?
CTS and Neuspeed make them.
http://m.ebay.com/itm/261675948859?_mwBanner=1
Ive seen a few people use these :happy2: not sure if you'll get hit with charges tho? Seems cheap for both pipes
Mike, did you make this upgrade ?, I saw a thread a while back where you raised the question. Not sure if you did in the end ? :smiley:
it basically lets the air flow quicker to the engine.
think of it like how you fit a 3inch exhaust to get the gasses out of the engine.... these pipes increase the flow into to engine
Is it worth doing ? :smiley:
if you want the best out of you setup the yeah :happy2:
Thanks mate. I see awesome have the neuspeed turbo outlet but can't see the throttle pipe ?, is the turbo one the main one ?
https://www.awesomegti.com/shop-by-car/audi/s3-8p/neuspeed-2-0t-fsi-k04-hi-flow-turbo-discharge-pipe-kit/
the outlet pipe you posted will only fit k04...
https://www.awesomegti.com/shop-by-brand/neuspeed/neuspeed-hi-flow-intercooler-pipe-conversion-2-0t-fsi/
this throttle pipe is for k03 by the way
I am K04, so should be fine. Thanks
In that case that is the one
Think I'm right in saying the CTS pipes have a bigger bore than the Neuspeed ones. 2.5" rather than 2.25".
Double check that, because I'm not 100%, but it might be worth considering.
I have Neusped discharge pipe and custom AKS tuning throttle body pipe. Every little helps when making it flow & breathe better
Recently fitted the discharge and throttle pipes to my ED30 and noticed bugger all, so put the standard ones back. The K04 pipes aren't as small as the K03 ones though, which is probably why!
