All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: BenJeffrey on September 03, 2016, 05:33:32 pm
Title: MFD2 iPhone uses
Post by: BenJeffrey on September 03, 2016, 05:33:32 pm
Evening all,
I can't seem to find anything in search (probably can't use the function properly) but needing some guidance.
Car came with MFD2 and there is an older style 30 pin iPhone cable coming from behind the headunit, providing the AUX and charging facility for the phone. From this cable, can you also play video into the headunit? I've tried but no luck, just producing a blank screen.
Just to add, i'm using a 30 pin to lightning adapter for my iPhone 5s, could this be the issue and I need a newer VW cable?
Cheers  :happy2:
Title: Re: MFD2 iPhone uses
Post by: Pashka on September 03, 2016, 10:30:00 pm
Evening all,
Cheers  :happy2:
Not possible.
