All Things Mk5 => Mk5 General Area => Topic started by: veedubster on September 10, 2016, 03:09:58 pm
Title: Xenons unsure if LHD or RHD
Post by: veedubster on September 10, 2016, 03:09:58 pm
I've just got some Xenons for my Golf but I'm unsure if they are LHD or RHD ones.
The part numbers are
1K6 941 032
1K6 941 031
Could any confirm please?
If they are LHD, I've heard there is a tab switch to switch them. If so, where is this tab switch and how do I adjust them?
Title: Re: Xenons unsure if LHD or RHD
Post by: DrG_GTi on September 11, 2016, 11:00:10 am
Its pretty straight forward, inside each xenon projector unit there is a metal tab off to the outside (you can see them from the outside if you look carefully), you simply need to flick these the opposite to what they are right now, pop the rubber caps off (and the plug if needed) and carefully with a screwdriver/or finger if you don't have sausages like me) flick the tab up/down
Post by: veedubster on September 11, 2016, 11:12:33 am
Thanks for replying.
I can see there are metal tabs on both sides in the xenon project unit. If I flick the tab up on the right hand side, the tab on the left hand side goes down. Which side should I be adjusting?
Also do you know what is UK (up or down). I'm not sure if someone has made the adjustment before.
Post by: veedubster on September 13, 2016, 11:16:36 am
Anyone?
I've tried to google but some previous help pdfs links have stopped working :(
Post by: r5gtt on September 13, 2016, 11:02:49 pm
On the audi tt mk1 UK was 0 and Europe was 1 if that's any good to you.
Post by: 99hagued on September 14, 2016, 12:53:27 am
The tab adjuster thing in the headlight is to get rid of the kick off on the beam image so instead of kicking off the the near side it just makes the beam image a straight line, so if u was to take the car to Europe u wouldn't dazzle oncoming cars if that make sense
