All Things Mk5 => Mk5 General Area => Topic started by: Prewy on September 17, 2016, 03:28:29 pm
Title: DV question
Post by: Prewy on September 17, 2016, 03:28:29 pm
So there I was  bored on a Friday afternoon, decided to drop my DV off and check condition. Been meaning to for a little while, even though if it was knackered I had no replacement!
Anyway up on the ramps and off it came, guessing it was original, had rev c on it. Looked in perfect condition, now I had no symptoms and this was purely an inspection. My question is would this be normal or has my car had an easy life? Should I bother changing  it as car is still standard?
Guess what I am ultimately getting at is the fact I thought I was missing something when you read of all the failures. 07 55k
Title: Re: DV question
Post by: slix on September 17, 2016, 03:49:39 pm
Yeah just leave it and check every service for condition, or if you get running problems. Then maybe upgrade to a rev G.
No point fixing something that isn't broken.
Post by: bonelorry on September 17, 2016, 04:17:32 pm
Every One I removed has always looked in good condition but I fitted the latest Revision G for piece of mind!
For a fit and forget solution there is always the GFB-DV+, You can retain your existing solenoid but replace the weak parts and you get an improvement in throttle response too!
