		All Things Mk5 => Mk5 General Area => Topic started by: gazaai on October 07, 2016, 08:32:46 pm
				Need help with my 05 GTI, cant rev it over 2k or else it backfires, engine jolts around a lot as well and wont hold boost.
 I have several fault codes here in which I've tried changing the ECU, replaced Engine Wiring Loom & replaced Intake Manifold motor.
 Codes are still present:
 012691 - Intake Manifold Runner Control
 P3193 - 002 - Open Stop outside of Valid Range
 Freeze Frame:
 Fault Status: 01100010
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 173929 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 17:58:28
 Freeze Frame:
 RPM: 0 /min
 Load: 0.0 %
 Speed: 0.0 km/h
 Temperature: 85.0°C
 Temperature: 41.0°C
 Absolute Pres.: 1000.0 mbar
 Voltage: 12.446 V
 001602 - Sensor Reference Voltage A: Circuit
 P0642 - 002 - Low - MIL ON
 Freeze Frame:
 Fault Status: 11100010
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 173929 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 17:58:28
 Freeze Frame:
 RPM: 0 /min
 Load: 0.0 %
 Speed: 0.0 km/h
 Temperature: 85.0°C
 Temperature: 41.0°C
 Voltage: 12.446 V
 004248 - Intake Manifold Tuning Valve Position Sensor (G336)
 P1098 - 001 - Open or Short to Plus
 Freeze Frame:
 Fault Status: 01100001
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 173929 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 17:58:28
 Freeze Frame:
 RPM: 0 /min
 Load: 0.0 %
 Speed: 0.0 km/h
 Temperature: 85.0°C
 Temperature: 41.0°C
 Voltage: 12.446 V
 012556 - Low Pressure Fuel Regulation
 P310C - 004 - Fuel Pressure Drops Intermittently
 Freeze Frame:
 Fault Status: 01100100
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 173929 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 17:58:55
 Freeze Frame:
 RPM: 854 /min
 Load: 19.2 %
 Speed: 0.0 km/h
 Temperature: 84.0°C
 Temperature: 38.0°C
 Voltage: 13.970 V
 004917 - Engine Torque Monitor 2
 P1335 - 008 - Control Limit Exceeded - Intermittent
 Freeze Frame:
 Fault Status: 00101000
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 173953 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 18:29:42
 Freeze Frame:
 RPM: 2606 /min
 Load: 32.5 %
 Speed: 106.0 km/h
 Temperature: 96.0°C
 Temperature: 18.0°C
 Voltage: 14.351 V
 Any help would be appreciated, Cheers
 *** PROBLEM SOLVED ***
 Problem is now solved, I had two failed sensors on the car:
 - Low Fuel Pressure Sensor (06E 906 051 K) - Caused the Low Pressure Fuel Pump to run at 90% constantly.
- MAP Sensor (038 906 051 D) - Caused the intake manifold codes to be present, and car was unable to boost correctly.
 How I found these faults:
 By Logging the fuel preasure on VCDS I could see something was wrong:
 (https://i.gyazo.com/98e56f5dfef3e04aff61a8c9d9aa3042.jpg)
 The fuel pump was running at 90% consistently.
 I tried the following to the car:
 - New Fuel Line to Filter
- New Fuel Filter (correct 6.6 Bar one)
- New Low Pressure Fuel Pump
 After this same again:
 (https://i.gyazo.com/3fcd5897ec3ce59f4ef321ab974ee101.jpg)
 Next on the list was to try a New Low Fuel Pressure Sensor, after changing this it now looked like this:
 (https://i.gyazo.com/761091625671c915ad85d7e373af5f1b.jpg)
 This solved the issue with my fuelling causing a backfire, and I found the MAP Sensor to blame for the other intake manifold codes.
 Hope this helps other people out :smiley:
 Fault Codes I had for anyone searching on google:
 Freeze Frame:
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 174469 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 16:05:33
 Freeze Frame:
 RPM: 0 /min
 Load: 0.0 %
 Speed: 0.0 km/h
 Temperature: 38.0°C
 Temperature: 21.0°C
 Absolute Pres.: 990.0 mbar
 Voltage: 12.192 V
 Freeze Frame:
 Fault Priority: 0
 Fault Frequency: 6
 Reset counter: 255
 Mileage: 174469 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 16:05:33
 Freeze Frame:
 RPM: 0 /min
 Load: 0.0 %
 Speed: 0.0 km/h
 Temperature: 38.0°C
 Temperature: 21.0°C
 Voltage: 12.192 V
 Freeze Frame:
 Fault Priority: 0
 Fault Frequency: 3
 Reset counter: 255
 Mileage: 174469 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 16:05:34
 Freeze Frame:
 RPM: 2244 /min
 Load: 23.1 %
 Speed: 44.0 km/h
 Temperature: 95.0°C
 Temperature: 20.0°C
 Absolute Pres.: 980.0 mbar
 Voltage: 14.224 V
 012555 - Low Pressure Fuel regulation
 P310B - 008 - Fuel Pressure Outside Specification
 Freeze Frame:
 Fault Status: 01101000
 Fault Priority: 0
 Fault Frequency: 9
 Reset counter: 255
 Mileage: 174469 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 17:00:26
 Freeze Frame:
 RPM: 2075 /min
 Load: 28.6 %
 Speed: 29.0 km/h
 Temperature: 83.0°C
 Temperature: 18.0°C
 Voltage: 13.970 V
 000566 - Manifold Pressure / Boost Sensor (G31)
 P0236 - 008 - Implausible Signal
 Freeze Frame:
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 174524 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 00:21:12
 Freeze Frame:
 RPM: 0 /min
 Load: 0.0 %
 Speed: 0.0 km/h
 Temperature: 76.0°C
 Temperature: 39.0°C
 Absolute Pres.: 1010.0 mbar
 Voltage: 12.319 V
 Freeze Frame:
 Fault Priority: 0
 Fault Frequency: 1
 Reset counter: 255
 Mileage: 174527 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 00:24:52
 Freeze Frame:
 RPM: 2585 /min
 Load: 32.5 %
 Speed: 105.0 km/h
 Temperature: 82.0°C
 Temperature: 15.0°C
 Voltage: 14.097 V
				Just a stab in the dark but maybe the flaps themselves are clogged up with carbon, so not being able to physically move? Or highly unlikely but a faulty new motor?
				I had the same a while back but once I cleared the fault a couple of times it stopped showing the fault. I've since bought the Runner flat delete but haven't fitted it in as yet. Clear fault drive a few days anc check again, if fault persists replace rf motor!.
				The faults won't clear just come back instantly without even starting the engine.
 Already tried:
 Changing ECU
 Changing entire engine loom
 Changing Flap motor
 I really don't want to drive it for much longer like this. It even spits flames lol on gear changes, the pops don't sound healthy at all. Just waiting for it too bend a valve or something. I don't see a runner flap delete sorting this will it?
				No the rdf won't resolve this issue.
 Check these out mate
 http://wiki.ross-tech.com/wiki/index.php/17026/P0642/001602
 http://wiki.ross-tech.com/wiki/index.php/17506/P1098/004248
 http://wiki.ross-tech.com/wiki/index.php/19649/P3193/012691
				Yeah I've had a look at those mate but it points to all the things I've already replaced  :sad1:
 Dunno what else is left to try
				Was the motor anew part?.
 Have you had injectors tested checked?
				Nah the motor was a used part but same part code. Do you think I should buy another and try it out?
 No, I would rather get rid of these codes as I think it's to do with that. I mean the codes are here and won't go away even clearing them with engine off. So don't think injector related
				Ive read on another  forum that it could well be an injector at fault but can't be 100% I'm afraid. Bucking could be a sign of a failed coil pack too. Check coil packs and plug for any usually burning.
				Well R8 coilpacks and NGK Irdiun spark plugs were just fitted 2k ago. Still have old ones in shed so might be worth a try. I just don't see how an injector would be related
				If you're not getting enough fuel Coming through then it wil misfire. Hopefully someone in the know might be able to help but that's all I can think of mate.
 Have a read of this
 http://www.golfmkv.com/forums/showthread.php?t=184663
 Good night
				Good night mate but the car ain't misfiring it's back firing on letting off throttle after using boost. Even spits flames lol
 Definitely need to sort out these manifold codes first, might even need to take it to VW to see what they think.
				Definitely sounds like fuelling issues if it's spitting out flames Over fuelling!.
 https://m.youtube.com/watch?v=bgS3PA5r0vY
				Yeah but won't these faults be making it fuel the car wrong. That's why I'm trying to get rid of them first before I look into Fueling issues.
				The car will obviously fuel wrong if backfire is evident.
 Some say valve springs can be broken others say car may need decoking.
 Get a compression test done to rule then out.
 Have you tried driving with around with the air flow sensor off?.
				Could also be your knock sensors under the inlet mani and there's two one to the right and one to the left
				http://www.mk5golfgti.co.uk/forum/index.php/topic,69032.60.html
 Thanks for the help everyone, the fix is on the first post now :smiley:
