All Things Mk5 => Mk5 General Area => Topic started by: GTInMining on October 08, 2016, 01:17:18 pm
Title: Cam chain + tensioner, or adjuster as well?
Post by: GTInMining on October 08, 2016, 01:17:18 pm
My '06 sounds really quite 'diesely' when warm and after research have concluded it needs a new cam chain and tensioner (Hopefully not adjuster too!). I've been quoted by Midland VW (with genuine parts) to do:
£895: updated cam adjuster housing, cam shaft adjuster, cam chain, cam chain tensioner and the oil pump pick up pipe
£360: chain and tensioner.
Without taking the car down there they've suggested I do the bigger job, but is it necessary? Thanks  :smiley:
Title: Re: Cam chain + tensioner cost? Midlands independent recommendations?
Post by: slix on October 08, 2016, 04:43:47 pm
How many miles has the car done? As they are pretty noisy on idle do to the injectors.
Post by: mart. on October 08, 2016, 04:54:10 pm
Based in Nottingham. Took mine to lindleys. Just under £400 with genuine parts.
Post by: GTInMining on October 08, 2016, 05:23:44 pm
115k, you can hear it inside and outside the car, I'm sure it's not right...
Post by: GTInMining on October 08, 2016, 05:26:10 pm
Bit more than I was hoping for if I'm honest! I don't know whether to bring it back to Evans Halshaw, I just feel they'll say there's nothing wrong with it. I guess I want reassuring that if the chain snaps a few months down the line, I'll be able to get it repaired under consumer rights act etc.
Post by: AJP on October 08, 2016, 05:31:03 pm
If it's a knock knock chug chug type of noise it'll be the chain. Injectors make more of a ticking noise.
Title: Re: Cam chain + tensioner, or adjuster as well?
Post by: GTInMining on October 10, 2016, 06:17:40 pm
Does anybody have any experience in these parts failing? I just don't know if this should be urgent or something to get around to in a few months?
Post by: doylebros on October 10, 2016, 06:44:32 pm
This is worth a read http://www.mk5golfgti.co.uk/forum/index.php/topic,106158.0.html
This is also worth reading http://www.mk5golfgti.co.uk/forum/index.php/topic,64912.0.html
