		General => Random Chat => Topic started by: Juliand on October 12, 2016, 08:54:25 am
				I have an elderly neighbor who is 'babysitting' her daughters car while she is out of the country for a few months. She doesn't drive herself now, so the car is just sitting in the garage, battery going flat, etc. I said that I would do some research on trickle chargers for her - something she can leave on and not worry, if there is such a thing.
I suppose she should move it occasionally too, to prevent flat spots on tyres? Anything else, please?
				i purchased a smart charger which so far has been very good
				I have a CTEK, supposed to be the dogs b's...at >£65 it should be, but turned out to not be very durable, lecky at work has since fixed it for me.
When parked outside i use a Maplins solar panel and that has been V good,  also used one on the boat and proved to be weather resistant ok.
Otherwise...
Leave hand brake off, and chock wheels.
Make sure plenty of anti freeze/ anti corrosion additive. Ideally change the oil and brake fluids, but probably too late for that?
Yes - try to Move car a short distance at least every month or so, to avoid flat spotting tyres.
How damp/well ventilated is the garage? Keep it either well vented, or sealed up and dehumidified, perhaps use some of those window crystal things to prevent moulds inside?
I used to leave my car for 4-5 months regularly when working overseas.
The clutch on the TR5/6 was prone to sticking to flywheel, so used to keep it off with a piece of timber on the pedal/seat frame! Dont know if thats  necessary with these cars?
