All Things Mk5 => Mk5 General Area => Topic started by: lukemk5gti on October 13, 2016, 02:59:01 pm
Title: Condensation Rear Light
Post by: lukemk5gti on October 13, 2016, 02:59:01 pm
I've had this issue in all of my outer rear lights in the past.
I was able to rectify this in the past by drilling a small hole in the bottom of the lights to allow for drainage.
This light for some reason just will not stop fogging up. Any suggestions? I've already drilled both bottom corners.
Title: Re: Condensation Rear Light
Post by: r5gtt on October 13, 2016, 05:04:28 pm
Take the lights out and remove the bulb holders and you should try and reseat the sponges and clean the dirt out.
Post by: Mark_DF05 on October 14, 2016, 08:19:54 am
I removed mine, dried it out with a hairdryer and then went over the seals with clear silicone. It's been fine since
Post by: mk5Eire on October 14, 2016, 08:31:43 am
Another tip after you've dried them out is to place those silica gels at the back of the light it helps absorb any moisture that might leak through.  I done it on both my tailight and one of the headlights that was leaking moisture.  Solved the issue
Sent from my SM-G930F using Tapatalk
Post by: lukemk5gti on October 14, 2016, 09:21:42 am
Tried it
Tried it
And Tried it
Cannot get this last bloody light to stop it. This is my set of ed30 rears and I've fixed 7 in the past.
I'm convinced someone is injecting water into it at night  :signLOL:
