All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: SiofChester on November 06, 2016, 01:32:53 pm
Title: Anyone test rear view cameras?
Post by: SiofChester on November 06, 2016, 01:32:53 pm
Bought a MK 6 rear view camera off a lad on here but can't get it to work. I've bought a loom converter but it still won't work, even when I try wiring it manually to a 12v source to replicate going into reverse.
Rather than jump to the conclusion that I've been stiffed by a member on here, does anyone test these things that could give me a hint if it's the unit or my installation skills...
Title: Re: Anyone test rear view cameras?
Post by: RetroRaz on November 06, 2016, 01:51:19 pm
How have u wired it?
Post by: doylebros on November 06, 2016, 02:22:14 pm
This is well worth a read http://www.mk5golfgti.co.uk/forum/index.php/topic,10027.0.html
Post by: SiofChester on November 06, 2016, 04:20:20 pm
I put the loom between the existing wiring to the old latch and then did (from memory) 2x 12v connections to a 12v dc transformer and a ground. Was expecting the camera to pop open or move when I put 12v to the "reverse light wire"
Post by: RetroRaz on November 06, 2016, 04:20:50 pm
Did u ground it as well to the black wire?
Post by: SiofChester on November 06, 2016, 04:24:05 pm
Yeah, it's a kufatec wiring loom I bought I believe
Post by: SiofChester on November 06, 2016, 04:25:09 pm
To be fair, the only thing I didn't do, is run the wiring to the head unit
Post by: RetroRaz on November 06, 2016, 04:28:30 pm
I would just fit it to the car straight without using a dc transformer.
Post by: SiofChester on November 06, 2016, 04:33:21 pm
I tried that with a spare battery I had but nothing, hence me thinking the unit was faulty. It was brand new though, so it's likely to be me
Post by: SiofChester on November 06, 2016, 07:01:16 pm
One final thing I noticed was that eve with 12v hard wired to the unit, when I pulled the latch up, it didn't make any noise, not even the boot lock actuator, which it does with the MK 5 latch
Post by: SiofChester on November 09, 2016, 04:09:03 pm
Anyone else got any advice?
