All Things Mk5 => Mk5 General Area => Topic started by: Jaks101 on November 29, 2016, 06:00:39 pm
Title: Help deciphering VCDS scan
Post by: Jaks101 on November 29, 2016, 06:00:39 pm
Hi guys
I need some expertise and Help deciphering VCDS result.
My symptoms seem to be some sort of battery drain, I recently replaced both door locks as they were faulty and I have also replaced the battery so it's not that.
Some of my errors relate to the radio as I don't have one at the moment and can someone point me in the right direction for the alarm malfunctions I'm thinking maybe a fuse has been pulled in the past as the faulty door locks were maybe setting off the alarm. There is a lot of unknown history with this vehicle too!!.
Tuesday,29,November,2016,17:14:32:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WVWZZZ1KZ6W014474   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ6W014474   Mileage: 181430km-112735miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2233597
   Coding: 0403000318070060
   Shop #: WSC 00655 210 56975
   VCID: 63C5C5EAA294925ADD-8036
3 Faults Found:
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100100
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 0.0°C
                    Temperature: 0.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.938 V
001299 - Incorrect Immobilizer Key
               P0513 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 181437 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 23:58:41
             Freeze Frame:
                    RPM: 1561 /min
                    Load: 15.7 %
                    Speed: 0.0 km/h
                    Temperature: 0.0°C
                    Temperature: 0.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.811 V
Readiness: 0110 0001
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   Shop #: WSC 01279 785 00200
   VCID: 408F2A661342E942E0-8014
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AT
   Component: ClimatronicPQ35 066 0606
   Shop #: WSC 00000 000 00000
   VCID: 79F987823018788AE7-802C
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003148021
   Coding: E58D0F2700041800001400001400000000087F075C
   Shop #: WSC 01279 786 00200
   VCID: 2B556DCA8AC41A1A25-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 01279
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00207646
   Shop #: WSC 01279
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0FBCND
   Coding: 0012870
   Shop #: WSC 01269 785 00200
   VCID: 377D41BA468CAEFA51-8062
   Subsystem 1 - Serial number: 6332MSME0A25652DE
   Subsystem 2 - Serial number: 6342MSME0A59277FR
   Subsystem 3 - Serial number: 6351HSME075D1E37H
   Subsystem 4 - Serial number: 6361HSME075C1D7BO
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000012
   VCID: 76E38CBE010617F28A-8022
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 962
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0003403
   Shop #: WSC 80093 222 69422
   VCID: 6ED3A4DE79562F3242-803A
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105609033E
   Coding: 3D3F0348071003
   Shop #: WSC 00857 210 91303
   VCID: 2A5B68CE853E0312DE-807E
3 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 181437 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:14:02
01300 - Control Module for Navigation with CD-Rom (J401)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 181437 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:14:06
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 128
                    Mileage: 181437 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:14:06
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1012
   Shop #: WSC 00137 211 56823
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2348
   Coding: 0000692
   VCID: 36634CBE418657F24A-8062
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 00655 210 91767
   VCID: 35614BB25C805CEA43-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01C802087F2D8405485FC69010CC
   Shop #: WSC 00046 412 819200
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000692
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2423
   Coding: 0000144
   VCID: 336575AA52F442DA6D-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 346776B657FA45E274-8060
End-------------------------(Elapsed Time: 01:33)--------------------------
Title: Re: Help deciphering VCDS scan
Post by: pudding on November 30, 2016, 01:49:55 pm
I believe many alarm fault codes can be attributed to a duff siren module, which is under one of the front wheel arch covers I believe.  It has an internal battery which dies or something.  Interior ultrasonic sensors can be flakey too.
How long is the battery taking to flatten?   You can also get P1602 from disconnecting the battery.   Have you tried clearing the codes and see which ones come back repeatedly?
Post by: Jaks101 on December 02, 2016, 10:07:42 am
 I think I'm going to try a new alarm module as I know the ara doesn't sound so it's worth a try.
I was just worried as none of the alarm sensors respond so I was thinking that it could be the alarm module that is duff.
Thanks for the advice
Post by: pudding on December 02, 2016, 10:25:44 am
I've got siren and interior monitoring sensor fault codes too.  Let me know if replacing the siren module solves your problems!  I hear it is pretty expensive from VW tho!
Post by: f00glee on December 02, 2016, 12:56:16 pm
Ive got a "genuine" bosch siren module on its way from china as we speak. If I fit mine and its any good, ill be sure to post up the link. FYI it was £25odd rather than the ~£150 from western suppliers!
EDIT: You wont believe this but as I finished the above, the post arrived at my desk, and within I found the module! Shipping from china was quicker than expected, at around 10 days. On Ffirst inspection looks legit with the righ p/no and stamping etc. Will be a few weeks before I fit, so cant comment on operation of the part. Searching ebay for "1k0 951 605 C", the first result is the one I went for @£25.16.
Post by: pudding on December 02, 2016, 02:20:18 pm
£150 for that!!  A little plastic box with a speaker in it, madness!!
Yeah keep us posted mate  :smiley:
Post by: r5gtt on December 02, 2016, 05:19:16 pm
Retroraz had used to China one and it works perfectly so there's no reason not to buy one and comes with an extended wiring harness so I'm sure it can also be relocated or need be  :happy2:
Post by: Jaks101 on December 02, 2016, 09:26:37 pm
Haha, just bought one from aliexpress myself £25 notes.
Will let you know how I get on when it arrives hopefully this year.
Post by: RetroRaz on December 02, 2016, 10:35:16 pm
Yep, i have bought 2 China ones for both golfs i had. Worked no problems for 2 years
Post by: Jaks101 on December 03, 2016, 06:11:53 pm
Did you have battery drain problems when your alarm wasn't working ?
Post by: r5gtt on December 03, 2016, 08:50:17 pm
Some have battery drain and others like mine just has the error code till you replace the siren fitted right hand drivers side under the arch gaurd in the alloy box  :stupid:
Post by: RetroRaz on December 03, 2016, 10:00:03 pm
Mine didn't have battery drain issues
