All Things Mk5 => Mk5 General Area => Topic started by: Vithu06 on December 15, 2016, 12:54:39 pm
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fuploads.tapatalk-cdn.com%2F20161215%2F9a12264c5f550e73476628d2b192f2e2.jpg&hash=f48c59624417d4698924ef343b33144ee8af039a)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fuploads.tapatalk-cdn.com%2F20161215%2F2f6d02df8b3bddc7a604cbc6df9f8f41.jpg&hash=89a0d6023eb186786b136ac8080a3abf2e254b82)
Tried removing the faults but they don't erase. I want to be able to fix it myself than spend money someone please help
Have you done any work recently?
The brake one I had a play when i got vagcom new and I want to return it to default
Ok second pic I noticed the date is on 2000
Youve activated the ESP calibration - you need to complete it - you can't just clear it: http://wiki.ross-tech.com/wiki/index.php/ESP_System_Function_Test
As for the second image, take a look here but it sounds like you'll need a new instrument cluster which requires specialist coding - not a DIY: http://wiki.ross-tech.com/wiki/index.php/01317
Perform the basic setting in the ABS
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60)#Basic_Setting
then complete the function test
http://wiki.ross-tech.com/wiki/index.php/ESP_System_Function_Test_(Conti/Teves)
I wouldn't worry about the cluster fault if it only is in the radio
Probably an issue with the Chinese radio not getting the message from a newer cluster. Might also have to do with the coding in the radio
