All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: AlexR1823 on December 20, 2016, 05:10:45 pm
Title: MDI Sound Quality
Post by: AlexR1823 on December 20, 2016, 05:10:45 pm
So I attempted an MDI retrofit at the weekend, but the sound quality is poor through the MDI box, I know the MP3 files are fine because they play through my dads car perfectly.
I read that swapping pins may be required, I tried swapping the ground pin from 2 to 3 but that did nothing, are there any other possible fixes to this issue?
Also, found this on my-gti if it helps:
http://www.my-gti.com/1328/auxiliary-input-audio-sound-quality-problems-after-changing-head-unit
Title: Re: MDI Sound Quality
Post by: Andy on December 20, 2016, 11:56:07 pm
fitted one to mine the other week and it sounds fine
Post by: Pashka on December 21, 2016, 08:58:10 am
Check the loom for breaks.
Post by: StephenED30 on December 21, 2016, 05:08:55 pm
Try going into the settings, somewhere the input is set to low, try it on medium or even high. see if it makes a difference, it did on mine.  :happy2:
Post by: AlexR1823 on January 01, 2017, 04:51:05 pm
Checked the loom and can't see anything obvious.
Also there is no option for AUX input level? Checked in all the settings and cant find anything.
