All Things Mk5 => Mk5 General Area => Topic started by: ConorGTI on December 24, 2016, 07:14:52 pm
Trouble tonight lads, felt like I'd lost boost or it had gone into safe mode. These are what codes I got.. I've recently fitted a ram air induction kit so could be to do with that? Any help is appreciated.. can't believe I've got 7 bloody faults :sad1:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fw413%2Fconordaniel%2FA433B127-2FE1-4032-AFFB-5B225C586DFA_zpssfmakaje.png&hash=55481798345b6a14eaed3539783d0c5f55f7cd18)
With a new intake installed you need to inspect that all connections are sealed. If you cannot find what is allowing more air or even less fuel...you may just need a new 1st position O2(closest to the engine) or a new MAF. If you clear the codes and unplug the MAF and it runs better...try a new MAF. Likely need to run data for fuel pressures as well with injector replacement or nozzle cleaning lastly.
Possible Causes for P0171
Mass Air Flow Sensor (G70) defective
Intake System Leak(s)
Possible Solutions
Check Mass Air Flow Sensor (G70)
Check Fuel Pressure Regulation
Check Fuel Pump
Check Injectors
Check Intake System for Leaks
Check Exhaust System for Leaks
Check Secondary Air System for Leaks
Check Vacuum Pipes for Leaks
Possible Causes for P2177
Fuel Pump (G6) faulty
Mass Air Flow (MAF) Sensor (G70) faulty
Intake System leaking
Exhaust System leaking
Wrong Fuel Pressure Sensor (G247) on Fuel Rail
Possible Solutions
Check Mass Air Flow (MAF) Sensor (G70)
Check Fuel Pump (G6)
Check Fuel Injectors
Check Intake System
Confirm correct Fuel Pressure Sensor (G247) part number
