All Things Mk5 => Mk5 General Area => Topic started by: Duffmeister on December 28, 2016, 10:41:42 pm
As above, does anybody know the correct description or part number for these? Mine are all rusted out :confused:
left: 1K0615311F
right: 1K0615312F
Ordered, thanks mate
Do you know the part numbers for the rears? mine are starting to move about a bit tooo much!!
Removed mine as there no use at all. May stop 1% of dust and boulders but what about the 99% that squeeeeeel when trapped :drinking:
For years I'd have said the same as you. But as Pudding pointed out in a different thread, they will prevent grease hitting the brakes if a CV joint spews its guts. Plus, if you're tracking a car, and generating a bit of heat, they'll shield your lines from the heat.
The rears... Mine are getting f*cked off as soon as I get the chance. All they do is trap stones/grit.
ETA... Just to ruin my argument, I removed them on the front when I got the Clubsports fitted. No issues yet...
I have ordered both sides as I think I'm going to have to take the hub off to get the original off so I figured I might as well put some back on!
Went and scratched the alloy in taking it off though!!
