All Things Mk5 => Mk5 General Area => Topic started by: K9 on January 05, 2017, 06:45:25 pm
Title: Can thsi bolt be replaced without...?
Post by: K9 on January 05, 2017, 06:45:25 pm
Hey. A time ago when i swaped oem bushes to WALK  kits and one bolt snapped in the subframe and is now drilled out with the threads, there is a long bolt now sticking thrue the subframe and a locking washer on the topside. Question is now that can i make Aligments and the remove this bolt without caussing the aligment to go crazy again? I'm talking about one of the 16mm bolt tthat is securing the console bush to the subframe.
Thanks!
Title: Re: Can thsi bolt be replaced without...?
Post by: pudding on January 07, 2017, 04:04:02 pm
If you don't disturb the other 2 bolts, the alignment won't change  :happy2:
