All Things Mk5 => Mk5 General Area => Topic started by: Cadders96 on January 20, 2017, 08:09:42 am
Title: Brakes - What Discs and Pads (Stock)
Post by: Cadders96 on January 20, 2017, 08:09:42 am
I am looking to change my pads and discs on my mk5 GTI in the next few months as I think they are starting to go. Anyone know a good combo of pads and discs for the stock mk5 GTI brakes? Thanks!!
Title: Re: Brakes - What Discs and Pads (Stock)
Post by: peter_booker2003 on January 20, 2017, 08:28:34 am
I've recently replaced both front pads and discs for Pagid from ECP. Paid £107 for pads and discs.
Post by: richtung on January 20, 2017, 08:34:48 am
Give your local TPS a call for a quote on OEM Pads and Discs. Even as a retail customer they tend to offer decent discounts!
Rich
Post by: AJP on January 20, 2017, 09:14:18 am
Yeah OEM Pagid from ECP tick the boxes. They seem to constantly be having some sort of sale too. You can often pick things up with about 30% off.
Post by: Dan_FR on January 20, 2017, 09:20:07 am
Even better to look on carparts4less - same company just mail order only and usually cheaper too
Can't fault Pagid - used them for years
Post by: dronners on January 20, 2017, 12:47:50 pm
pagid is a good choice but throwing it out there as an alternative mintex are pretty good
Post by: Cadders96 on January 20, 2017, 01:51:31 pm
Wasn't just saying OEM brake pads and discs btw guys :happy2: Meant Stock Calipers what could I get with these that are good and not overly expensive!
Post by: Cadders96 on January 20, 2017, 01:51:47 pm
Will have a look at mintex
Post by: Dan_FR on January 20, 2017, 02:06:04 pm
What's important is usage. As a 'fast road' or 'track' pad compound has a different temperature window you may find these may actually be worse if you only do the occasional sudden stop. If you really work your brakes hard and get some proper temperature (to the point where they start to fade and you lose confidence) then I would look to a fast road pad to go with the standard discs
Post by: Cadders96 on January 20, 2017, 02:56:29 pm
I would say I need fast road pads as I do hit the limit of the pads quite a lot at the moment so tend to brake a lot earlier if I know the brakes are very hot :scared: any recommendations?
