All Things Mk5 => Mk5 General Area => Topic started by: Bozz on January 24, 2017, 07:00:58 pm
Title: Removing letters
Post by: Bozz on January 24, 2017, 07:00:58 pm
Hi all, I'm thinking of taking the 2.0 TDI letters off the tailgate but I just wondered if it'll leave marks ? Thanks
Title: Re: Removing letters
Post by: slix on January 24, 2017, 07:03:24 pm
No marks just residue.
Use fishing wire or credit card to remove then use wd40 or similar to get the rest of the sticky stuff off. Then follow up with a bit of Polish if needed.
Post by: Andy on January 24, 2017, 07:46:49 pm
I used a credit card and tar and glue to get the residue.My old gttdi
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fcc20%2Fmaxitrol%2F20140906_184647_zpsswaddhl2.jpg&hash=561917d258588dddaef418d44a0a2ce13cb1d89b)
Post by: Bozz on January 24, 2017, 07:49:38 pm
Thanks both :)
Post by: dronners on January 24, 2017, 08:46:39 pm
if you heat the letters up with a hairdryer or what i did was pour hot water over them it softens the glue so more comes off with the badge and you'll have less work cleaning up whats left
Post by: AJP on January 24, 2017, 08:58:44 pm
Dental floss. Cuts through the adhesive nicely.
Then the usual tar/residue remover.
On some cars a light cut then polish was needed as a final stage as the paint under the badge hadn't been subject to the same weathering and/or washing and polishing as the rest of the car, so you'd end up with a kind of 'stencil' of the badge.
Done.
Post by: shoaybmakda on January 24, 2017, 10:21:57 pm
Thanks for this - been meaning to replace my rear badges with the new MK7 red badges I've got. These tips will come in handy!
Post by: spesh on January 29, 2017, 11:24:02 am
WD40 works fine for removing the residue, bit cheaper than the tar remover too ;)
Post by: LNeoPT on January 30, 2017, 01:21:43 pm
I removed mine and i got them "marked" at the paint. Already tried to polish it but i can't remove the burn.
