All Things Mk5 => Mk5 General Area => Topic started by: Black9 on February 19, 2017, 10:03:55 pm
What's the size of the oil filter housing on the GTI? Is it 38 or 40mm? Any help appreciated
I think it's a 36mm socket.
Can anyone confirm? Tried a 36 today and it wouldnt fit?
Yep, 36mm
As above, 36mm shallow socket designed for oil filters. I have one of these:
http://www.ebay.co.uk/itm/-/320959798246
I ordered one of those sockets last night.
Also one of these looks like it will be useful
http://www.ebay.co.uk/itm/Draper-VAG-Group-Oil-Filter-Drain-Hose-PN-ORH-VAG-/291759036791?hash=item43ee319977:g:fJYAAOSw3zxXL7mW
Let us know if it fits and works. I have been after one for a while.
http://www.micksgarage.com/blog/project-gti-oil-and-filter-change/
How very useful! Ordered :smiley:
There worse than useless, i threw mine in the bin after the second attempt to use it :fighting:
Ahh.. thats a shame. the 'OEM' one works great and its made out of metal, but pricey
https://www.amazon.co.uk/Assenmacher-ASST40057-Filter-Housing-Drain/dp/B002YK9L6S
Par for the course with ebay shat :grin:
To be fair, I just shove an allen key into the orange nipple, lift it up and move it over so it rests on what ever is inside there, and wait for it to drain out. No hardship really. I just thought this gadget might speed the process up, but sounds like it's a more of a hindrance than a help!
Does the tube get air locked or something, or does the screw in bit just not lift the nipple up, or something?
£151....ouch
Yeah it airlocks, 45 minutes waiting for it to drain, undo it and get covered in oil.
Maybe that's the problem it doesn't screw up enough to really push into the nipple, happened to me twice, so in the bin in went :angry015:
Oh well, if that happens, that is the feedback I shall be leaving on ebay then :smiley:
I can't seem to get the oil filter housing off mine at all. I have a 36mm socket!!
Any tips for one that is stuck fast in there? Have ordered a replacement just in case alsp
I did mine a couple of weeks ago and for some reason the 36mm I thought it would be wouldn't fit, so I had to nip to halfords and bought a 38mm one and worked fine :happy2:
It's probably been over tightened. Very common. You'll need a breaker bar to get enough torque to crack it free. Just as well you have a new one because over tightened ones often break upon removal!
£151....ouch
£151!?!
Unbelievable!
I'll get some more rags then....
i just used a big phillips head screw driver and pushed the valve in then re-seated it afterwards....
i think i'd do that again and keep the £150
Yep, that's all I've ever done without any problems.
£151....ouch
£151!?!
Unbelievable!
Yes. It is somewhat over priced. :smiley:
You could do as I did and get the ECS Tuning filter housing
https://www.ecstuning.com/b-ecs-parts/billet-aluminum-oil-filter-housing-kit-silver-anodized/003602ecs01a01a/
Mmmmmm......nice!
How much is a new standard one?
Mmmmmm......nice!
Got a new standard for £27 on eBay yesterday
Will be a replica/chinese special for that price I imagine?
New genuine is over £100
You don't actually have to drain the oil filter housing before removing it but it probably helps to prevent oil spillage.
This is the one I ordered http://www.ebay.co.uk/itm/142258631812
Same as this, just twice the price
https://www.aliexpress.com/store/product/Plastic-Oil-Filter-Cap-917-049-06D115408B-For-VW-Beetle-Golf-Jetta-Passat-Bora-Eos-Rabbit/107412_32597867187.html
Notice that the eBay does not say GENUINE anywhere
Saw the one on Ali but couldn't wait for the shipping time. Hopefully it lasts!! :surprised:
The gti has a paper filter inside the housing? I ordered a Bosch filter from ecp and it's not a paper filter but A metal screw on one.. will this still fit and is it correct?
No, you need a paper one.
Yeah you ordered the wrong one
TBH I hadn't realised there was such a thing! Thanks for linky!
I Ordered the 3/8" drive Sealy version (also slightly cheaper!) From
http://www.ebay.co.uk/itm/121755523240?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Has arrived and quality etc aok.
Figured as I had been using a 36mm 3/4 drive impact socket i was already well tooled up for any stuck housings :signLOL:
And my new one will be v considerably easier to work with overhead!
You can shop around on ebay and get it for the same price. The one I originally posted was the first result. Can't remember which actual link i purchased though as it was years ago
http://www.ebay.co.uk/itm/-/361724368138
I'll be swapping it around on sat. Ecp sent me the wrong one.. Shld have know tbh :signLOL:
They also sent me the wrong oil. Ordered Castrol edge 5w 30 got 0w 30 :signLOL:
