All Things Mk5 => How to Guides / Troubleshooting => Topic started by: readie on February 28, 2017, 02:24:11 pm
Title: rear lights
Post by: readie on February 28, 2017, 02:24:11 pm
hi why does my rearlight keep misting up ive brought a new bulb holder dryed the light out with a hairdryer as sone as i put the thing back in it misted up  :confused: :confused:
Title: Re: rear lights
Post by: Shamm on February 28, 2017, 02:45:49 pm
Check closely you might have a slight crack
Post by: readie on February 28, 2017, 03:11:22 pm
it only does it on the drivers side ive brought a secondhand lamp still misted up :confused:
Post by: Shamm on March 01, 2017, 07:09:32 am
Again you should check maybe there is a slight crack
Post by: DrG_GTi on March 01, 2017, 01:07:43 pm
I had this years ago with an old clio, sometimes the plastic deteriorates to the point where hairline cracks appear, and/or the seal fails.
I sorted it by putting one of these inside, bit sh*te but it fixed it and didn't have to buy another unit....  :jumpmove:
http://www.ebay.co.uk/itm/like/360917050738 (http://www.ebay.co.uk/itm/like/360917050738)
Post by: lukemk5gti on March 01, 2017, 02:11:31 pm
Happens to a huge number of people including myself.
My original lights had the issue and I replaced them with R32 ones again with the same issue.
Dry them out fully and then use clear silicone to seal the top and sides of the light casing with your finger.
The part where the red plastic front of the light meets the black plastic frame.
You won't see a leak but water does get pulled in.
Post by: readie on March 01, 2017, 03:46:44 pm
Did that sort the problem ??
Post by: lukemk5gti on March 02, 2017, 09:41:05 am
Immediately.
Suffered with condensation on those new lights for about 6 months.
