All Things Mk5 => Mk5 General Area => Topic started by: Scottymon on March 20, 2017, 06:55:14 pm
Title: Wheel Bearing Front
Post by: Scottymon on March 20, 2017, 06:55:14 pm
Got a quote today for Drivers Side Front Wheel Bearing replacement... said it needs to the whole hub and would cost £238 including... ( Edit: TOTAL JOB PRICE, SUPPLY AND FIT, GEN PARTS )
Can't the bearing be replaced without changing the Hub?
If not, is that a fair price for supplying and fitting a new hub with Genuine Parts?
Title: Re: Wheel Bearing Front
Post by: ChrisGT on March 20, 2017, 07:27:47 pm
Unfortunately it does have to be the whole hub that's replaced.
Something like 60 or 80 quid for the hub/bearing (sure you can get cheaper ones off ebay but I probably wouldn't...) plus 2 to 3 hours labour at something like 50 or 60 quid an hour then your quote sounds about right.
Chris
Post by: Scottymon on March 20, 2017, 07:38:56 pm
Cheers Chris, hmm, suppose I could call around for a few more prices, but I have a feeling it's going to be around the same.  Going to be a pricey month, four new tyres, discs/pads all round, rear calipers, service and this wheel bearing... ouch.
Thanks for your input (y)
Post by: ChrisGT on March 20, 2017, 07:54:15 pm
Ouch indeed...  :doh:
Always worth getting quotes from a few places.
Chris
Post by: Lewo on March 20, 2017, 09:52:46 pm
From memory when I looked through the old paperwork for my car a rear VW bearing was around £130, can't remember if the fronts were the same, can check for you if you like.
Post by: Adam0604 on March 20, 2017, 10:24:55 pm
If it's anything like the rears, it takes 45 mins at tops to change.
Front wheel bearing off ECP is circa £90 - £110 dependent on brand you go for.
Post by: r5gtt on March 21, 2017, 01:32:22 am
That's extortion and I personally wouldn't pay that for a hub from the stealers as Eurocarparts will do the same job for half that price tbh.
Post by: ady-uk on March 21, 2017, 08:26:01 am
Just be careful though.....if you buy cheap, you'll probably get speed sensor / abs fault.
It is really common problem with 'spurious' bearings / hubs fitted.  Not made to same high standard.
I think here, I would only use genuine!
Post by: Pesky jones on March 21, 2017, 09:38:48 am
I bought a hub from eurocarparts for half the price. Then I returned it and bought a genuine one for full price (£130). Difference being the eurocarparts hub (lucas) gave abs and other associated errors. Euros not bad for some things, but not our hubs!
Post by: r5gtt on March 21, 2017, 09:46:05 am
ow thanks for the head ups  :happy2: didn't think they've be that bad as others have used them but then again we are talking eurocarparts  :doh:
Post by: r5gtt on March 21, 2017, 09:47:19 am
nice one, will think twice about it now  :signLOL:  :stupid:
Post by: Shoduchi on March 21, 2017, 04:35:13 pm
You can buy SKF or FAG. Both make the genuine hubs. Cheaper and same quality. I have a friend that bought a SKF and it had the VW branding too. :laugh:
Post by: r5gtt on March 21, 2017, 05:59:26 pm
I've used skf before but on a different car. :happy2:
Post by: Scottymon on March 21, 2017, 06:35:25 pm
I should've written that better, it is £238 fitted (using gen parts).
Had a quote from VW themselves, they wanted £359 fitted.
Had another quote with pattern part from VW Specialist for £150 fitted.
Post by: Scottymon on March 21, 2017, 06:41:26 pm
Thanks for the response guys
It's going in tomorrow, so I want to see the invoice of the part I'm paying for, I think it's only fair....
Brands to look out for ?  SKF ?
Post by: skard on March 21, 2017, 07:35:18 pm
I got a genuine one for £34 (old stock) on eBay. Other dealers are selling them for £80-90 new.
1-1.5 hours to do, depending on how nicely the bolts want to come off.
I think FAG make the OEM ones, have never had many issues with SKF though.
Post by: r5gtt on March 21, 2017, 09:06:29 pm
3 hrs labour  :thinking: or £75 ph  :surprised:
Post by: r5gtt on March 21, 2017, 09:07:35 pm
I remember the name fag from the 80's that's bearing related  :happy2:
Yeah shouldn't take no more than 2 hours of labour especially with it being on a ramp.
Post by: Scottymon on March 21, 2017, 09:42:37 pm
Christ, seems expensive... they have been really good before too, hmmm
Post by: r5gtt on March 21, 2017, 10:05:27 pm
yes it does mate that's why I wondered what happened there.  :doh:
Post by: Lewo on March 21, 2017, 10:22:52 pm
I had to look!
In 2014 at maindealers it cost £300 fitted  :rolleye:
1.5 hrs labour at £99 ph + VAT, front bearing £111 + VAT  :jumping:
Post by: r5gtt on March 21, 2017, 10:36:45 pm
My local vw dealer charge £149.00 per hour labour for anything
Post by: Lewo on March 22, 2017, 06:20:47 am
  :surprised:
jeez, I thought 120 was enough  :rolleye:
Post by: r5gtt on March 22, 2017, 11:55:53 am
It's criminal to pay and a free cup of tea if you're waiting  :signLOL:
Post by: Scottymon on March 22, 2017, 07:43:08 pm
Well it's been sorted, old bearing completely toast, rough... however an old noise that I thought was the wheel bearing progressing is still there... perhaps driveshaft?
Happens around 20-25mph, on load more than off... then completely disappears ... it's been there for about 2 years... no splits in the gaiters, but I have had them replaced a while back so perhaps some ingress.
Anyway, cheers for the input guys. (y)
Post by: Lewo on March 22, 2017, 08:16:48 pm
Which bearing make did you go for in the end?
