All Things Mk5 => Mk5 General Area => Topic started by: lukemk5gti on April 07, 2017, 10:27:06 am
Firstly, anyone know the easiest way to post a video?
Secondly, my gearstick has a little play. As in it can wobble around about 1cm diameter when in neutral.
Can I tighten this up? Gear linkage or short shifter?
Advice appreciated.
Upload to youtube, post a link
Shifter bushes from 42DD/AKS needed to tighten that up usually
Cheers Dan,
These? http://www.akstuning.co.uk/aks/142-aks-solid-shifter-bracket-bushes.html?search_query=shifter+bushes&results=1
They are for the bracket, which will help but is not the main culprit. It the shifter bushes that make the biggest difference but the type you need varies on the year (there are several) See here for example: https://www.awesomegti.com/shop-by-brand/42-draft-designs/?search_query=&page=1&limit=16&sort=priceasc&Sub%20Part=Shifter&category=1405&is_category_page=1
