All Things Mk5 => Mk5 General Area => Topic started by: Christiank on April 11, 2017, 03:33:10 pm
Title: Which door modules for 4door, lhd when I want to retrofit folding mirrors etc?
Post by: Christiank on April 11, 2017, 03:33:10 pm
All right guys.. Tried to search this topic on Google and there's so many different answers to the subject.
Hoping if I posted here to get some clear answer on what modules that'll support the mods I need to do..
I want folding mirrors, puddle lights, trunk pop fuel switch, door entry lights and indoor door handle illumination.
I got electric windows on all 4 doors and it's a LHD.
Title: Re: Which door modules for 4door, lhd when I want to retrofit folding mirrors etc?
Post by: SI-R32 on April 11, 2017, 05:31:35 pm
What about reverse dip on passenger side mirror?
Have you got the folding mirrors yet? You might also want to consider anti dazzle on drivers mirror (extra wiring inside car needed)
Post by: Christiank on April 11, 2017, 05:57:18 pm
I got dip on passenger with the polar-fis "kessy" box so this isn't needed.
Was thinking about doing the side mirrors to anti dazzle also but my plans were to retrofit a pair of scirocco mirrors with puddle and folding function instead of the mk5 ones since they doesn't fold that much.. Already got a bodyshop working on the mirrors, just need to source out which door module I need.
My current ones are  : 1K0 959 701 E / 1K0 959 702 E in the front and 1K0 959 703 C / 1K0 959 704 C in the rear doors
Post by: Cr33D on April 11, 2017, 06:26:13 pm
Reverse dip is mirror dependent. Passenger mirror with reverse dip does have additional (if I remember correct 3 or 4) wires.
You will need gen2 max controllers or gen3 controllers. This can be identified by number of pins in the control module (should have all of them). I can try to get you some part numbers from ETKA, if you will struggle to find anything on ebay.
Check here for identification of all of the pins.
http://www.my-gti.com/2158/volkswagen-golf-jetta-door-controller-information-mark-v
Switching between different gens will require some pins to be changed.
Regards
Cr33D
Post by: Christiank on April 11, 2017, 09:08:16 pm
Actually I've already bought some modules that should support the pins for the retrofits I'll be doing.
They have part numbers : 1K0 959 792 P / 1K0 959 793 H.
Can't remember from which cars they're from ... Only thing I can remember is that my passenger window didn't work a neither did the right side mirror? Anyone know if these modules can be used or should I try locate some Generation 3 (M, N or Q) instead?
Post by: Cr33D on April 11, 2017, 09:38:12 pm
When was your golf produced ?
Sent from my EVA-L09 using Tapatalk
Post by: Christiank on April 11, 2017, 10:06:24 pm
It's a MY2005 2.0TDI
Post by: Cr33D on April 11, 2017, 10:54:32 pm
So your wiring is gen1/2 R modules are gen 3 by the look. You need to  modify wiring as per link I gave you.
Post by: Christiank on April 12, 2017, 12:20:18 pm
So I'm able to use the modules I've already got or should I search down some Gen 3 (m,n,q) from Ebay? :)
Post by: Cr33D on April 12, 2017, 01:12:26 pm
When I will get home from work I will check vcds label file for you, as I think that R are gen3 already. If they are from post 2007 mk5 this should be the case.
Post by: Cr33D on April 12, 2017, 06:20:12 pm
Any chance you can get me a part numbers of the motors that you have attached to this modules as this is how VCDS is identifying GEN of the modules.
I don't know why but for some reason i thought that your modules are "R"...
So I think that:
1k0 959 793H was fitted with 1k0 959 701L which is Gen2 High
1K0 959 792P was fitted with 1k0 959 702L which is Gen2 High
Although please confirm I am correct, if so ignore my previous post about Gen3 and wiring changes.
When you connected new modules which errors you had ? have you coded them in via VCDS ?
Regards
Cr33D
Post by: Christiank on April 13, 2017, 04:37:41 pm
Yeah mate. I'll be back home Tuesday - Then I'll have a look there :)
I'll give you a PB when I'm back as a reminder :)
