All Things Mk5 => Mk5 General Area => Topic started by: Christiank on April 17, 2017, 10:35:28 am
Hey.
As the tittle says... Anyone tried out the VWR ‘Cup Edition’ Front Suspension Upgrade Kit with the alloy wishbone and stuff?
(VWR45G5COMP)
Also read that some changed to the Audi TT or the Audi S3 ones - Maybe that's cheaper?
- Couldn't really get if it was a direct fit or the TT ones need some drilling of some kind and the S3 ones is a direct fit..
Any inputs will be great since I'm doing mine a the nearest future :)
It looks rather like the Superpro lca kit though I would be interested to hear whether there are any differences.
You mean the £540 wishbone, console bush, and ball joint kit from Awesome?
No need to spend that kind of money:
Passat B6 alloy wishbones, tenner each on ebay.
Passat B6 ball joints, £46 each from VW.
WALK or S3 console bushes. £150 ish.
Job done.
Optionally you can add Passat B6 alloy hubs as well for £20 each from ebay.
Job done.
Do you have part numbers for the b6 alloy wishbones? Ta
Job done.
Every time I get a p/n off the internet, it's always wrong at the dealer, or VW have changed it, so best bet is to do an ebay search mate. You defo don't want to be buying them brand new. Crazy money.
Job done.
Found a few on eBay, cheapest one is £15 per side(cheap) they're off a 1.9tdi Passat b6 estate....part numbers 3C0407153D, 3C0407153B...
Was hoping to match your part numbers with these before I get em...
EDIT: sorry for the threadjack
Job done.
Yep they are the fellas :happy2:
All B6 Passats basically have MK5 Golf suspension, but the Passat being more premium than the Golf, it got Ally arms and hubs instead of steel/iron.
8P S3 got exactly the same alloy parts also, but they get a huge scene tax applied to them.
Top stuff
getting them now, they come with the consoles too lol but I'll be sticking my alk on em. Thanks mate
Yeah they can be a bugger to get off, so most sellers leave them on!
No worries!
So whichever B6 passat hubs you get will be 55mm strut?
I believe so yes. I ordered a random pair of B6 hubs from a 2007 random Passat on the bay, and the 55mm VWR spring/damper kit I bought for a MK5 Golf bolted straight in :happy2:
Ahh.... Thanks @Pudding (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=10733) I'll try search some B6 Passat ones from eBay.
I guess they ones I'll find would be full or old dirt - Got any recommendations on how to clean them up the best way? Since I really don't like putting some fresh bushed and joints to some old dirty wishbone :booty:
I got a LHD mk5 , should I be on the lookout due to LHD or RHD restrictions?
Have a look at vapour blasting that should get a dirty set cleaned up like new.
I didn't bother cleaning my wishbones but I put the alloy hubs in the dishwasher! Came up great :happy2:
You'll need to check, but I think they are the same both sides. You just turn them over. That was the case on my wife's Beetle anyway.
Think it's the same partnumber for both sides.
So you wouldn't have any thoughts on buying a pair that has 150.000km? :innocent:
So long as they are straight, 150,000km is no problem.
No worries!
They arrived today, needs a good clean lol
Weighed them, 3kg each, that's including the console....sound about right?
Sounds good. I ordered some today myself. Should arrive mid next week. Also purchased some sodablower gear to clean em up.. Guess I'll give all parts in beneath the car a run over to clean the bits up. :)
No worries!
I didn't weigh mine mate, but Shodouchi reckoned the steel ones are 4kg and the Passat ones are 2kg, less the consoles I assume. I can quite believe that because when I held both in my hand, the Passat one was considerably lighter!
No worries!
I didn't weigh mine mate, but Shoduchi reckoned the steel ones are 4kg and the Passat ones are 2kg, less the consoles I assume. I can quite believe that because when I held both in my hand, the Passat one was considerably lighter!
That's it. Without consoles since I just needed the wishbones. I kept my PU bushes, front from Powerflex and rear from SuperPro with anti-lift kit. I also bought new Passat ball joints. :smiley:
@Pudding @Shoduchi Will the gti ball joints be ok on the Passat wishbones?
@Pudding (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=10733) @Shoduchi (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=10590) Will the gti ball joints be ok on the Passat wishbones?
Yes, but the Passat ball joints will correct a bit the roll centre. You just need to use new nuts for your ball joints. They're one use only, ideally.
Ta
getting all the bits in before Saturday, just need to order the ball joints then. Hopefully I don't regret going for the black series ALK and front bushings, 95 shore!
Purple is 80...
Will have to wait and see if I knock my fillings loose
Ta
Purple is 80...
If you don't track the car I don't think the Black series is advised... I have road series SuperPro ALK and it has done 4 track days so far. No issues. It has some compliance to lessen a bit the road NVM.
So I'm getting my alloy wishbones from the B6 Passat along with some Audi TT bushes from darkside developments.
@Shoduchi (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=10590) should I just ring up VW and order some now ball joints from a passat b6 or which did you go with? :)
Also is there anything else I need to order before I can get them installed?
Not sure about the TT bushes. I prefer them from SuperPro that I also have in my GT Sport (the ones with anti-lift).
You can see what I did when I made that upgrade with part numbers included here: http://www.mk5golfgti.co.uk/forum/index.php/topic,95592.msg1079220.html#msg1079220 (http://www.mk5golfgti.co.uk/forum/index.php/topic,95592.msg1079220.html#msg1079220)
:wink:
Went with the TT/S3 ones since my xar actually will never see a track day. So just trying to improve the ride for some highway trips :)
-Left ball joint: 3C0407365B
-Right ball joint: 3C0407366B
-Nuts: 6x N10332002
These partnumbers will also fit my 3C0407153B wishbones? :innocent:
-Nuts: 6x N10332002
I don't and won't ever track my diesel GT Sport but I loved the handling improvement that the SuperPro rear bushes with anti-lift gave, without compromising the driving comfort.
The parts listed are used in all Passats B6, so they're all compatible. Your wishbones are just a different revision from mine.
Anybody know the difference between these two parts of any..Passat B6 front control arm:-3C0407153B and also found control arm:-3C0407151G which says Passat/Sharan and other VAG cars
Both look identical to me 😕
If you check ETKA you can't find this part number: 3C0407153B. It's weird. They both look the same, so I don't know why the different part number. :confused:
I can see both on eBay for sale... I agree both look identical, think I’ve established that the ‘3C0407153B’ is from the Passat B6 running 2006/2010 year so I’m presuming the ‘3C0407151G’ is from the later 2010 run VAG cars but not 100% sure
I should be ok buying x2 ‘3C0407153B’ used control arms from eBay as will purchase new Passat B6 ball joints aswell then I’m gunna buy the superpro front control bush kit and fit all the lot, then get car realigned on a Hunter Hawk or something similar 👍🏼
Hoping everything fits..I like to do as much homework as possible as I get very annoyed once there with tools if bodying is required :doh:
#bodging
Stick with OEM front wishbone bushes. I hear from a number of respected tuners that aftermarket poly bushes are not an improvement at all over the stock parts. Worse in some cases. I know the early SuperPro front bushes caused problems. Not sure if the revised ones are any better, but I opted to leave those off mine and just fitted the consoles. No complaints. Great steering and no wheel tramping.
I have the superpro lower arm kit plus balljoints, complete with the road durometer poly bushes. The ensemble droves very nicely, with incisive steering and no adverse NVH issues.
You're just posh, Mr 'Supaloy' :smiley:
The BF price I got wasn’t much different to buying old passat ones plus SALK plus front bushes and paying to get them pressed. I do however have some grubby old Passat B6 alloy hubs just delivered, sadly Superpro didn’t stock any shiny new ones 😂
Hmmm, decisions decisions..was going to give the arms a good clean then fit the superpro complete bush kit at work as can use our hydraulic press then it would just be a matter of removing my OEM arms and replacing with the 2nd hand Passat ones & fitting the new genuine Passat ball joints at the same time.
Not looking for anything to drastic, just a lighter & stiffer standard set up with new ball joints and a good old alignment
Sounds like a plan Acko but why not get some adjustable bjs and achieve some more negative camber at the same time? Here’s an extract from today’s Evo roadtest of the optimistically priced Seat Cupra R
“while the strut front suspension has been adjusted to deliver greater negative camber in an attempt to improve turn-in and front-end grip – it has been increased from 1.3 degrees to two degrees.“
2 degrees is a lot for a road car. I bet the tramlining and lorry rut weaving isn't pleasant. It's bad enough with -1, let alone double that!
Not to worry Kev as they won’t sell many of these at £35k.
Not as cash sales, but they will probably go in droves as leases!
They are only allocating 24 of this model to UK, so best form an orderly queue.......
Ah, OK. Is it Seat's version of the Clubsport S? Didn't know it existed until you mentioned it!
Maybe at a later date, them Superpro ball joints arnt half expensive but rightly so as you can fiddle with the camber and tweet set-up 👍🏼
I’ve managed to get both Passat arms at £15 each (eBay) brand new lemfonder Passat ball joints for £27 each (thinking there very similar to OEM) and the SuperPro control arm bush kit for £117 inc delivery BLACKFRIDAY special 😊
So not to bad overall
The front control arm rear SALK or ALK is that the same as the SuperPro complete bush kit I’ve just purchased once fitted or are the ‘ALK’s abit more offset to achieve more lift?! I’m still learning unfortunately but will get there haha...
Same caster increase. Just more work to get it well fitted, I think.
Yeah you have pretty much the same thing Acko. Keep in mind though that if you fit the adjustable bjs later then you will need to pay for a second alignment.
The complete kit should be the consoles and the front bushes. Rear bushes just move the wishbones out about 20mm, which tilts the whole strut forwards to give you more caster. The front bushes are fixed as per OEM. Did you buy the kit with the complete housings, or just the press-in bushes?
Yeah I’ve just bought the complete bush kit, not the rear consoles for front arm with SuperPro bush already fitted...
Looks like the kit I’ve bought is only standard upgraded replacement bushes, if you can see the diagram on the picture i’ve got the standard (SPF3271K) bushes & on the right of the diagram it shows (SPF3272K) bushes which create anti-lift
https://m.imgur.com/7w5p4yy
Yeah they are standard replacements, without the voids. SPF3272K is the steering pull correction kit. Only one bush is offset.
I think the anti lift press in bush kits have been discontinued as they don't show on SuperPro's site anymore. So you'll need ALOY3273-80K or ALOY3273-90K
The 90K one is stiffer. TBH your kit looks old anyway. The rotating insert is now a stainless steel sleeve, yours are the older poly on poly design.
Think the kit with rotating stainless insert is for track use, mine is only road use..but you could be rite maybe an old kit..did get the kit at a decent price! Would of preferred the anti-lift kit though
