All Things Mk5 => Mk5 General Area => Topic started by: IOMAL on April 18, 2017, 08:50:12 pm
the elec window won't go down from the passenger side but does go down from drivers side controls ,so it is working obviously a break in the wire ,where is the best place to start ,from the switch to the window or could the break be in the door gaitor?
Drivers side door wiring would be my starting point but you could check the switches with VCDS in output testes without any disassembly.
