All Things Mk5 => How to Guides / Troubleshooting => Topic started by: boost30 on April 20, 2017, 09:34:17 pm
Title: Error codes / Keeps returning
Post by: boost30 on April 20, 2017, 09:34:17 pm
Hi Guys,
I have an Eddy 93tkm on the clock, standard tune, hg motorsport cold air intake, fsw catback exhaust and that's about it. So it is pretty standard!
In the mornings (cold start) car struggles to start for a couple of seconds then fires (all starts after this are normal), proceeds to rev past 1000rpm and again dip below 800rpm (sometimes shuddering and going to stall but not always).
The car constantly seems to lose revs when going from start stops thus me having to keep it a couple of extra pushes on the gas to get it up, also when coming to a stop at a traffic light from third gear down and slow gently and clutch in the revs go below 500rpm and climb back to its regular position of 800rpm at idle.   :sick:
I had the car read out and the below codes appeared. Then I erased the codes and had it read out again as the CEL came up. Same codes.
I have changed the following within the last 2-4000km
- PCV
- DV
- cam follower (again checked last week and seems to be in good knick)
- MAF
ERROR CODES:
008568 - Bank 1 : Check engine light ON
P2178-002 System too rich off idle
001089 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 002
Any help would be of great help.  :thinking:
Just want the car to run well again.  :driver:
Thanks in advance!
MIKE
