All Things Mk5 => Mk5 General Area => Topic started by: Timsrs on May 02, 2017, 06:45:25 pm
Title: Wheel spacers for edition 30
Post by: Timsrs on May 02, 2017, 06:45:25 pm
Hi
Just purchased a stunning candy white edition 30
I am looking at getting the wheels refurbished in shadow chrome
I also want to fit wheel spacers to the car as well
I am after a more stance to the car nothing to much
What size spacers ( front and rear ) do most go for
I'm after a decent set and where's the best place to purchase
The car is lowered 30mm on H&R springs
Many thanks
Tim
Title: Re: Wheel spacers for edition 30
Post by: fab5freddy on May 02, 2017, 06:49:03 pm
If you're on standard offset, 7.5J ET51 then, 12mm front and 15mm rear, H&R would be my choice of quality brand. Not sure where the best place to buy is though
Post by: Octoparrot on May 02, 2017, 06:59:12 pm
Don't forget you'll need longer wheel bolts  as well.
Post by: Timsrs on May 02, 2017, 07:17:37 pm
Hi
Cheers yes it had standard 18" Pescara wheels
Post by: AJP on May 02, 2017, 07:29:06 pm
Standard bolts for OEM wheels are M14 x 1.5, 28mm thread length, radius seat.
Just add the spacer width to the thread length.
Post by: Timsrs on May 02, 2017, 07:33:17 pm
15mm on the rear looks like it will be flush with the arch
Will this catch with it going lowered
I agree will look fantastic though
Has anyone got a pic of 15mm rear spacers fitted
Post by: slix on May 02, 2017, 08:07:01 pm
I have 15mm on the rear of my ed30 with pescaras and can confirm it sits flush with the arch. Perfect imo.
Such a difference from running no spacers  :happy2:
Post by: Timsrs on May 02, 2017, 08:09:47 pm
Ok thanks
Have you a picture
Post by: Damian @ DPM on May 03, 2017, 03:46:02 pm
As people have said, 10/12mm front and 15mm rear looks pretty much perfect.
Damian @ DPM Performance
Post by: chigmuss on May 03, 2017, 10:33:19 pm
My 2p, I put 15mm spacers on the rear of my last ed and the pescaras rubbed over some bumps eventually rubbing through a tiny amount on the paint and liner. Mad me cringe every time it caught. On my current one I went with 12mm and not a hint of rub but still looks more stanced. On the previous car I had all the alignment checked etc so I don't know why some get away with it and I didn't. The car was wearing GY Eagles standard 225/18's.
So I'm 12mm all round now. NQSBBK on front.
Post by: rich83 on May 03, 2017, 11:11:36 pm
I would go 10mm front and rear.
Post by: MIJ_JAGGER on May 03, 2017, 11:20:43 pm
You reckon It'd rub with Eibach Sportlines? I'm on 18 monzas...want a more arch flush look
Post by: rich83 on May 04, 2017, 08:21:24 am
No you shouldn't rub with 10s
Post by: Damian @ DPM on May 04, 2017, 11:12:30 am
You may struggle to fit 10mm spacers on the rear, depending on brand, because of the depth of the rear hub lip.
Post by: Paradox1 on May 04, 2017, 11:28:19 am
et 41 and 20mm spacers on the rear. 15mm on the front and no rubbing
Post by: chigmuss on May 04, 2017, 09:34:00 pm
I believe I'm right in saying hubcentrics start at 12mm, ie they support the centre bore of the wheel when mounted up, the bolt is merely pulling the wheel onto the hub tightly. I've had 10mm ones (which had no 'support lip') and did get wheel vibration. So anything over 12mm you will be able to have as hubcentric.
Post by: MIJ_JAGGER on May 04, 2017, 10:13:44 pm
H&R makes 10mm hubcentric so does Eibach....
Post by: Timsrs on May 04, 2017, 11:00:47 pm
Do they do 8mm hubcentric
Post by: MIJ_JAGGER on May 04, 2017, 11:25:56 pm
Haven't seen any
Post by: AJP on May 04, 2017, 11:45:08 pm
I had 8mm H&R hubcentrics on the front of a mk4. They exist(ed).
BUT.....
Damian makes a good point. The rear hub 'protrusion' is often deeper than the front. Basically the inner bore of a hubcentric spacer can only be of a certain depth in order to allow the spacer to have a hubcentric lip.
In layman's terms, an 8mm or 10mm hubcentric spacer might not fit far enough onto the hub lip/protrusion. The spacer won't reach the disc.
On the mk4 at least - to confuse the situation further - some mk4s had deeper rear hub lips than others. So some people got away with 10/12mm spacers, while some people could only fit a minimum thickness of 15mm, and lots of people got the hump.
Some success was had with an angle grinder on the rear hub lip, but I'm not advising that...
I've probably described that terribly, I'll do a diagram to clarify if needed!
Post by: pudding on May 05, 2017, 09:51:47 am
 :surprised:
Reminds me of people cutting chunks out of the front chassis legs for driveshaft clearance because they've lowered the car so much, it's practically undriveable  :grin:
Any change in handling characteristics from spacers?
Post by: AJP on May 05, 2017, 10:33:47 am
 :surprised:
Yep, lots of chopping went on in the mk4 scene.
Theoretically if you widen the front track you'll get more rotation/turn in, and widening the rear decreases it, so increasing understeer. That's with a front wheel drive car at least.
It's nice to have a square set of wheels that fit nicely without having to use spacers!
Post by: pudding on May 05, 2017, 10:56:52 am
 :surprised:
You're not wrong.  I felt like an outcast having a standard R32 back in my MK4 days  :grin:
Check this out, it makes for horrifying, but not unsurprising viewing -
OK cool, I was tempted to move the standard wheels out a bit for more track and improve the visuals a bit, but was concerned it would ruin the handling.  And also moving the tyres further out flings up more stones and grit onto the arch lips and sills, and we all know how these cars like to rot in those areas, so didn't want to augment it!
Post by: AJP on May 05, 2017, 11:05:45 am
 :surprised:
I'll have a look at that this evening. Still need to watch the Stoptech vid too!
If you kept the wheels 'square', ie spaced the front and rear the same amount, you shouldn't get any negative effects (provided you kept things within sensible limits).
I'd imagine 10/12mm all round on a Pescara would be a nice result. And if the rear hub lip issue was apparent, you'd be fine with 12 front 15 rear.
It's only really the stancey 'staggered' setups (8" front 10" rear kind of thing) that really throw the handling.
A couple of mill isn't going to do a lot.
Post by: pudding on May 05, 2017, 11:57:48 am
OK cool, I like the sound of a subtle 10mm front and back  :smiley:
Post by: AJP on May 05, 2017, 07:06:17 pm
Just watched that vid @Pudding
Wow. What a pile of sh*t. I feel sorry for the guy that bought it. As they say - A little knowledge is a dangerous thing.
That attempt at a chassis notch?! And the nearside strut/hub just falling out...?! Deathtrap.
Post by: pudding on May 08, 2017, 01:58:09 pm
Awful wasn't it!  It had 'bodge' written all over it, especially when I saw plasti-dip overspray everywhere!
And the Lion Bar looking welding on the seat runners  :surprised:  It's a complete death trap!
