All Things Mk5 => How to Guides / Troubleshooting => Topic started by: njdudsbury on June 17, 2017, 10:15:04 pm
Car has developed a clunking / knocking noise from front end. Only does it on right lock forward and reverse but only when setting off. You can drive round in circles with right lock on and its quiet! Thought it may be cv joint but I'm not so sure now. Any ideas or experience of this??
Could be subframe shifting common problem.
What's the fix?
Awesome do an ECS subframe spacer kit - worked for me and is quite cheap
www.awesomegti.com/shop-by-brand/ecs-tuning/subframe-spacer-plates-kit-mk5-mk6-etc/
I had this kit it worked for abit then the knocking started again.
I've bought the Tyrol deadset kit and no more knocking, plus it's tightened the front end up lovely.
