All Things Mk5 => Mk5 General Area => Topic started by: Rossmk5gti on June 23, 2017, 08:56:18 am
Noticed recently not long after start up ill accelerate a little in second gear when climbing through the revs i can feel a vibrating/pulsating feeling which lags on performance for a few seconds other than that seems to drive fine! Wasn't sure if it was a coil pack or spark plug issue??
Also i notice my gearbox is a bit whiny in the lower gears 1-3 apparently its normal because of the way the gears are cut?
Sent from my SM-G935F using Tapatalk
