		All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Preece on July 03, 2017, 09:00:58 am
				Hi all,
 I have recently purchased a Mk5 Edition 30 and am having a problem with 3 re-occurring fault codes. The DV is the latest revision (albeit not fitted by me) and the car appears to drive well. there is a hesitation on Idle.
 Any advice is greatly appreciated  :happy2:
 Below are the codes that appeared last night;
 3 Faults Found:
 012408 - Throttle Control
 P3078 - 002 - Airflow at Idle too Low - Intermittent
 Freeze Frame:
 Fault Status: 00100010
 Fault Priority: 2
 Fault Frequency: 7
 Reset counter: 255
 Mileage: 135706 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 21:32:25
 Freeze Frame:
 RPM: 841 /min
 Load: 19.6 %
 Speed: 0.0 km/h
 Temperature: 82.0°C
 Temperature: 39.0°C
 Absolute Pres.: 990.0 mbar
 Voltage: 13.843 V
 001089 - EVAP Emission Control Sys
 P0441 - 002 - Incorrect Flow - Intermittent
 Freeze Frame:
 Fault Priority: 2
 Fault Frequency: 2
 Reset counter: 255
 Mileage: 142642 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 18:45:35
 Freeze Frame:
 RPM: 831 /min
 Load: 17.2 %
 Speed: 0.0 km/h
 Temperature: 81.0°C
 Temperature: 39.0°C
 Absolute Pres.: 1000.0 mbar
 Voltage: 13.843 V
 000051 - Turbocharger Bypass Valve Control Circuit
 P0033 - 004 - Malfunction / Open Circuit
 Freeze Frame:
 Fault Priority: 2
 Fault Frequency: 2
 Reset counter: 255
 Mileage: 142642 km
 Time Indication: 0
 Date: 2000.00.00
 Time: 18:45:35
