All Things Mk5 => Mk5 General Area => Topic started by: Dragonslayer2 on July 27, 2017, 11:07:32 am
Hi all,
Just wanted to see if anyone could help,
Replaced twice EGR value within 1 year by garage (One was replaced again under warranty and free of charge). This was done couple of weeks ago and already the dreaded P0401 has come up again this week.
Car is 2006 plate 1.6 FSI engine and engine is sound other than P0401 code keeps popping up.
Car does approx min 500 miles motorway driving per week.
Any suggestions?
So they replaced both the EGR-N18 and Potentiometer-G212(not sure if they come together or not)...but have they looked at the withdrawal tube, pn:03C131521T, to inspect whether or not it is stuck closed?
The code states under...Possible Causes
Exhaust Gas Recirculation (EGR) Flow restricted/clogged
Exhaust Gas Recirculation (EGR) Valve stuck closed/leaking/faulty
Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
Exhaust Gas Recirculation (EGR) System faulty
...and if your tube is similar to our 2.0t FSI, it has a simple valve inside that can/does get stuck. Mine was replaced twice...not because stuck, but for an open campaign when brought in for repairs.
The EGR is on page 9 here: http://www.volkspage.net/technik/ssp/ssp/SSP_296_d1.pdf
Hi ROH ECHT,
Thanks for the help so far!! This issue has been a nightmare over the last couple of weeks!
The EGR N18 and Part G212 were both new and come together.
Could possibly be withdrawal tube as there is two different ones fitted on EGR.
I am having trouble sourcing a new one, any ideas? most probably will be an ebay job..
