All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Bikerz on October 27, 2017, 06:38:47 pm
Mrs Mk5 BKC (1.9 PD 105) was running fine. Come to it after work and turn key and dash doesnt light up but stero comes on. Car cranks and starts then cuts out (like the imboliser type cut).
I will take VCDS to it tomorrow and check fuses and earths (Need to check the 109 relay too). Any advice on anything else? Anyway to check ignition switch without removing removing wheel and changing it?
Got to car this morning and it drives fine!
After this found fuse F25 which is 25a blown, which is for "Multifunction control module 1" Apparently. Whatever that is?
Any idea what else to check?
Saturday,28,October,2017,10:35:28:32772
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ1KZ5W187508 License Plate: SJ GOLF 28.10
Mileage: 139710km-86811mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ5W187508 Mileage: 139710km-86811miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 CB HW: 028 101 190 0
Component: R4 1,9L EDC 0000SG 6176
Revision: 12345678 Serial number: VWZ7Z0E1409633
Coding: 0000071
Shop #: WSC 01279 785 00200
VCID: 65CACA61ACE1C26E19-8030
3 Faults Found:
18058 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 64.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 110.0 Nm
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.54 V
Bin. Bits: 00000100
Bin. Bits: 11000000
(no units): 0.0
Freeze Frame:
RPM: 0 /min
Torque: 64.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00000100
Torque: 0.0 Nm
Torque: 110.0 Nm
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021121
VCID: 3A70491D75DF9D9684-806E
1 Fault Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EF
Component: Climatic PQ35 084 0404
Shop #: WSC 00000 000 00000
VCID: 6CDCBF454F0BF32646-8038
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
008 - Implausible Signal
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001346702
Coding: 00890F0600041800001400001400000000087B075C
VCID: 3972561170D9968E8D-806C
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
1 Fault Found:
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: 08 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD0410VT
Coding: 0012344
Shop #: WSC 01269 785 00200
VCID: 2C5C7F458F8B332606-8078
Subsystem 1 - Serial number: 6332MSME08534132/
Subsystem 2 - Serial number: 6342MSME0862133D8
Subsystem 3 - Serial number: 6351HSME05614635/
Subsystem 4 - Serial number: 6361HSME0610567B4
1 Fault Found:
004 - No Signal/Communication - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 E HW: 1K0 953 549 E
Component: Lenksäulenmodul 521 0050
Coding: 0000002
VCID: 346C672557BB6BE65E-8060
No fault code found.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 951 G
Component: KOMBIINSTRUMENT VDD 0716
Coding: 0003403
Shop #: WSC 80093 222 69422
VCID: 2D5A7241B4913A2E11-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104C1506DC
Coding: 3D0F0B40070003
VCID: 295286518079260EFD-807C
3 Faults Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 174
Mileage: 101447 km
Time Indication: 0
Date: 2000.00.00
Time: 16:03:59
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 174
Mileage: 101449 km
Time Indication: 0
Date: 2000.00.00
Time: 11:19:20
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 18
Reset counter: 214
Time Indication: 15
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0716
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0120
Coding: 0000052
VCID: 30646B35A3A357C63A-8064
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.2 1502
VCID: 31626E31A8A95ECE35-8064
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0562
Coding: 80C802087F2D8404085B018010
Shop #: WSC 00000 785 00200
VCID: 7BFE8C193A65649EDF-802E
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Component: Tuersteuergeraet 09 0168
Coding: 0000052
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
End-------------------------(Elapsed Time: 01:41)--------------------------
I would try another remote if you've got one as they do fail.
Both remotes do same thing
you have an issue with power getting to the cluster
there are 2 power feeds to the cluster
a permanent and switched live
